r0n4ld0l1n5
How can I use driver rtcticks.c |
Posted: Fri Jul 19, 2013 5:34 am |
Hello, my friends...
I am need help about driver rtcticks.c, please if somebody already used this driver help-me. I've tried and did not work the clock is moving forward.
thanks, |
Joined: 01 Jul 2010 Posts: 9459 Location: Greensville,Ontario
Posted: Fri Jul 19, 2013 6:01 am |
What version of the compiler do you have, as I don't have rtcticks.c in my drivers folder? |
r0n4ld0l1n5
Posted: Fri Jul 19, 2013 6:08 am |
The version of my CCS is 4.140. |
dyeatman
Posted: Fri Jul 19, 2013 6:29 am |
Yep, rtcticks.c is there, dated August 2012. _________________ Google and Forum Search are some of your best tools!!!! |
Posted: Fri Jul 19, 2013 7:52 am |
You have looked at the example that uses it?.
ex_time.c
Uses this if your chip does not have an internal or external rtc peripheral.
r0n4ld0l1n5
Posted: Tue Jul 23, 2013 5:05 am |
Yes, I looked... I think this problem is normal, because in all example happened the same thing... |
Re: How can I use driver rtcticks.c |
Posted: Tue Jul 23, 2013 2:13 pm |
r0n4ld0l1n5 wrote: | I've tried and did not work the clock is moving forward. | I'm sorry, but I don't understand what the problem is. Isn't a clock supposed to count forward?
Did you try the example program ex_time.c and did that solve your problem? |
