PIC interfacing with 74595 and 7 segment
syeda amna
PostPosted: Mon Mar 11, 2013 4:49 am     Reply with quote
Hi
I m trying to interface a 7 segment with PIC using 74595. I dont know where is the problem. I just want to display a number. plzz help me how to accomplish this task.
#INCLUDE <18F452.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=40000000)
#include <74595.c>
#define LATCH  PIN_B0
#define CLOCK  PIN_B1              //SH_CP
#define DATA   PIN_B2
void main() {
   int8 x=0;
   int8 y;
   int8 a = 0110000;  // 1
      output_low( LATCH );
      output_low( CLOCK );
      for(x=0;x<7;x++){
      y=bit_test(a,x);
      if(y==1){
      output_high( DATA );
      output_low( DATA );
      output_high( CLOCK );
      //STCP or LATCH will shift the data out when toggled
      output_high( LATCH );
PostPosted: Mon Mar 11, 2013 5:25 am     Reply with quote
You should really look at the files in the EXAMPLES folder that CCS supplies.In there is a a working program using the 74595 .
Once you have that 'up and running', expand the code to send '7-segment' data to the '595 that represents 0-1-2....9.
You could also search the forums here to see what others have done as you are not the first to ask for '595 help.
hth
jay
John P
PostPosted: Mon Mar 11, 2013 6:38 am     Reply with quote
One obvious problem--
int8 a = 0110000;
should be
int8 a = 0b01100000;
or
int8 a = 0b00110000;
Not clear which, because you've only put 7 bits in the byte.
And with a processor running at 40MHz, are the data lines changing too fast for the external component?
And, after this routine runs once, where is the program going to go?
Edited to say, the formatting here is atrocious, but as far as I can tell, the { and } marks are not balanced.
Mike Walne
PostPosted: Mon Mar 11, 2013 9:43 am     Reply with quote
You're not the first to do this project.
You've already been told, there are loads of examples from CCS, on the forum and google.
Your code won't compile, so we can't test it as is.
I try to arrange that each closing } is immediately below its opening {.
I've done this to your code and get this:-
#INCLUDE <18F452.h>
#include <74595.c>
#define DATA   PIN_B2
   int8 x=0;
   int8 y;
   for(x=0;x<7;x++)
      y=bit_test(a,x);
      if(y==1)
         output_low( DATA );
Can you see now why the compiler complains?
Mike
syeda amna
PostPosted: Tue Mar 12, 2013 2:28 am     Reply with quote
int8 a = 0110000;
should be
or
really an obvious mistake:oops:
thanks for your help.
PostPosted: Tue Mar 12, 2013 2:46 am     Reply with quote
40MHz, is _not_ a legal crystal speed for the PIC.
This part supports a maximum oscillator frequency of 25MHz. To work at 40Mhz, you have to use a 10MHz crystal, and the PLL, _or_ an external oscillator.... Classic 'read the data sheet'.
Mike has pointed out the other major problems....
syeda amna
PostPosted: Tue Mar 12, 2013 3:14 am     Reply with quote
Yes. It was my silly mistake Embarassed
thanks for your help Smile
