syeda amna
PIC interfacing with 74595 and 7 segment |
Posted: Mon Mar 11, 2013 4:49 am |
Hi
I m trying to interface a 7 segment with PIC using 74595. I dont know where is the problem. I just want to display a number. plzz help me how to accomplish this task.
#INCLUDE <18F452.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=40000000)
#include <74595.c>
#define LATCH PIN_B0
#define CLOCK PIN_B1 //SH_CP
#define DATA PIN_B2
void main() {
int8 x=0;
int8 y;
int8 a = 0110000; // 1
output_low( LATCH );
output_low( CLOCK );
for(x=0;x<7;x++){
y=bit_test(a,x);
if(y==1){
output_high( DATA );
output_low( DATA );
output_high( CLOCK );
//STCP or LATCH will shift the data out when toggled
output_high( LATCH );
Joined: 01 Jul 2010 Posts: 9166 Location: Greensville,Ontario
Posted: Mon Mar 11, 2013 5:25 am |
You should really look at the files in the EXAMPLES folder that CCS supplies.In there is a a working program using the 74595 .
Once you have that 'up and running', expand the code to send '7-segment' data to the '595 that represents 0-1-2....9.
You could also search the forums here to see what others have done as you are not the first to ask for '595 help.
hth
jay |
John P
Posted: Mon Mar 11, 2013 6:38 am |
One obvious problem--
int8 a = 0110000;
should be
int8 a = 0b01100000;
or
int8 a = 0b00110000;
Not clear which, because you've only put 7 bits in the byte.
And with a processor running at 40MHz, are the data lines changing too fast for the external component?
And, after this routine runs once, where is the program going to go?
Edited to say, the formatting here is atrocious, but as far as I can tell, the { and } marks are not balanced. |
Mike Walne
Posted: Mon Mar 11, 2013 9:43 am |
You're not the first to do this project.
You've already been told, there are loads of examples from CCS, on the forum and google.
Your code won't compile, so we can't test it as is.
I try to arrange that each closing } is immediately below its opening {.
I've done this to your code and get this:- Code: | #INCLUDE <18F452.h>
#include <74595.c>
#define DATA PIN_B2
int8 x=0;
int8 y;
for(x=0;x<7;x++)
y=bit_test(a,x);
if(y==1)
output_low( DATA );
Can you see now why the compiler complains?
Mike |
syeda amna
Posted: Tue Mar 12, 2013 2:28 am |
John P wrote: | One obvious problem--
int8 a = 0110000;
should be
or
really an obvious mistake:oops:
thanks for your help. |
Posted: Tue Mar 12, 2013 2:46 am |
40MHz, is _not_ a legal crystal speed for the PIC.
This part supports a maximum oscillator frequency of 25MHz. To work at 40Mhz, you have to use a 10MHz crystal, and the PLL, _or_ an external oscillator.... Classic 'read the data sheet'.
Mike has pointed out the other major problems....
syeda amna
Posted: Tue Mar 12, 2013 3:14 am |
Ttelmah wrote: | 40MHz, is _not_ a legal crystal speed for the PIC.
Yes. It was my silly mistake
thanks for your help ![Smile](images/smiles/icon_smile.gif) |
