Posted: Tue Feb 26, 2013 3:41 pm |
Flex LCD, is more flexible.
It allows operation with one less pin, and is easier to setup.
lcd.c, is potentially fractionally faster when using port wide mode, _but_ the LCD is so much slower than the processor that the difference is normally not measurable.
Flex LCD, is not a CCS replacement, it is a driver written by PCM programmer to really make driving these LCD's as easy as possible.
You can setup an LCD on any pin combination, and have it running in under 5 minutes with this, when lcd.c is likely to be more hassle to do.
