12f675
sabobey
12f675
PostPosted: Fri Oct 26, 2012 11:06 am     Reply with quote
How can I make with 12f675 three software pwm? I want to use on rgb. Thanks for your interest.
bkamen
PostPosted: Fri Oct 26, 2012 11:16 am     Reply with quote
With time, learning, the right tools and perseverance?
PostPosted: Fri Oct 26, 2012 11:33 am     Reply with quote
There is sample code in the Code Library forum for software PWM of 3 LEDs:
http://www.ccsinfo.com/forum/viewtopic.php?t=30139&highlight=red+green+blue
Mike Walne
PostPosted: Fri Oct 26, 2012 3:08 pm     Reply with quote
Start from from (say) a 4MHz clock that's 1us per instruction cycle.
Generate interrupts with one of the timers (probably timer0) at 10kHz.
In the ISR turn LEDs on and off as needed at 100Hz.
That will give you 1% resolution, and ~100 instruction cycles for the code to control the LEDs.
If you need either better resolution or more code you'll need a faster clock.
Best of luck.
Mike
