Posted: Fri Oct 26, 2012 3:08 pm
Start from from (say) a 4MHz clock that's 1us per instruction cycle.
Generate interrupts with one of the timers (probably timer0) at 10kHz.
In the ISR turn LEDs on and off as needed at 100Hz.
That will give you 1% resolution, and ~100 instruction cycles for the code to control the LEDs.
If you need either better resolution or more code you'll need a faster clock.
