jrugar
problem with sequence running [solved] |
Posted: Mon May 14, 2012 7:07 pm |
I am having a problem getting this code to work to run the sequence as I have it loading. I am trying to flash 8 leds on port b of a pic16f628. I have had it working other ways but wanted to make the c code smaller.
#include <16F628A.h>
#fuses INTRC_IO,NOPROTECT,NOWDT,PUT,NOMCLR
#use standard_io(b)
#byte port_b = 6
char rom led_tab[] = {0x00,0xFF,0x00,0xFF,0x00,0xFF,0xFF,0x00,
0x7F,0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE,
0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
0x7E,0xFF,0x7E,0xFF,0x7E,0xFF,0x7E,0xFF,
0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,
0xDB,0xFF,0xDB,0xFF,0xDB,0xFF,0xDB,0xFF,
0xE7,0xFF,0xE7,0xFF,0xE7,0xFF,0xE7,0xFF,
0x7E,0xFF,0x7E,0xFF,0x7E,0xFF,0x7E,0xFF};
set_TRIS_B(0x00); /* set port_b to be outputs */
PORTB = 0; /* initialize All port_b outputs to be zero */
while( TRUE )
/* forever loop using WHILE construct */
char i;
for(i=0; i<136; i++)
PORTB = led_tab[i];
when i run the above code in proteus all it does is all 8 leds light up and stay lit .and when i wrote it to the pic and tested it it does the same in hardware as well. |
jrugar
Posted: Mon May 14, 2012 7:19 pm |
Got it fixed after posting changed from char rom to char const and fixed my portb it should be port_b issue in the main code. |
jrugar
New Version of Code |
Posted: Tue May 15, 2012 1:24 am |
Use this code to help learn and make better things from it i am giving this version to the public to have fun with and learn.
* (c)2012 Joe Rugar *
* Pic16f628a LED sequence flasher v1.0 *
* This program is free software: you can redistribute it and/or modify *
* it under the terms of the GNU General Public License as published by *
* the Free Software Foundation, either version 3 of the License, or *
* (at your option) any later version. *
* This program is distributed in the hope that it will be useful, *
* but WITHOUT ANY WARRANTY; without even the implied warranty of *
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
* GNU General Public License for more details. *
* You should have received a copy of the GNU General Public License *
* along with this program. If not, see <http://www.gnu.org/licenses/>. *
#use standard_io(b)
#byte port_b = 6
char const led_tab[] = {0b00000000,0b11111111,0b00000000,0b11111111,0b00000000,0b11111111,0b00000000,0b11111111,
0b00000001,0b00000010,0b00000100,0b00001000,0b00010000,0b00100000,0b01000000,0b10000000,
0b10000000,0b01000000,0b00100000,0b00010000,0b00001000,0b00000100,0b00000010,0b00000001,
0b10000001,0b11000011,0b11100111,0b11111111,0b11111111,0b11100111,0b11000011,0b10000001,
0b00011000,0b00111100,0b01111110,0b11111111,0b11111111,0b01111110,0b00111100,0b00011000,
0b10011001,0b01100110,0b10011001,0b01100110,0b10011001,0b01100110,0b10011001,0b01100110,
0b11001100,0b00110011,0b11001100,0b00110011,0b00110011,0b11001100,0b00110011,0b11001100,
0b11000011,0b00111100,0b00111100,0b11000011,0b00111100,0b11000011,0b11000011,0b00111100,
0b11000011,0b00111100,0b00111100,0b11000011,0b00111100,0b11000011,0b11000011,0b00111100};
void seq1(void);
void seq2(void);
void seq3(void);
void seq4(void);
void seq5(void);
port_b = 0; /* initialize All port_b outputs to be zero */
while( TRUE )
seq1();
seq2();
seq3();
seq4();
seq5();
void seq1(void)
char i;
for(i=0; i<96; i++)
port_b = led_tab[i];
delay_ms(50);
void seq2(void)
char i;
for(i=0; i<96; i++)
void seq3(void)
char i;
for(i=0; i<96; i++)
delay_ms(70);
void seq4(void)
char i;
for(i=0; i<96; i++)
delay_ms(80);
void seq5(void)
char i;
for(i=0; i<96; i++)
delay_ms(30);
dyeatman
Posted: Tue May 15, 2012 5:40 am |
Thanks Joe! I am sure it will be beneficial to some of the folks here and
future visitors. Maybe a copy could be put in the Code Library? _________________ Google and Forum Search are some of your best tools!!!! |
