problem with sequence running [solved]
jrugar
PostPosted: Mon May 14, 2012 7:07 pm     Reply with quote
I am having a problem getting this code to work to run the sequence as I have it loading. I am trying to flash 8 leds on port b of a pic16f628. I have had it working other ways but wanted to make the c code smaller.
#include <16F628A.h>
#fuses INTRC_IO,NOPROTECT,NOWDT,PUT,NOMCLR
#use standard_io(b)
#byte port_b = 6
char rom led_tab[] =  {0x00,0xFF,0x00,0xFF,0x00,0xFF,0xFF,0x00,
                               0x7F,0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE,
                               0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
                               0x7E,0xFF,0x7E,0xFF,0x7E,0xFF,0x7E,0xFF,
                               0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,
                               0xDB,0xFF,0xDB,0xFF,0xDB,0xFF,0xDB,0xFF,
                               0xE7,0xFF,0xE7,0xFF,0xE7,0xFF,0xE7,0xFF,
                               0x7E,0xFF,0x7E,0xFF,0x7E,0xFF,0x7E,0xFF};
void  main(void)
set_TRIS_B(0x00); /* set port_b to be outputs */
PORTB = 0; /* initialize All port_b outputs to be zero */
while( TRUE )
   /* forever loop using WHILE construct */
   char i;
   for(i=0; i<136; i++)
      PORTB = led_tab[i];
when i run the above code in proteus all it does is all 8 leds light up and stay lit .and when i wrote it to the pic and tested it it does the same in hardware as well.
jrugar
PostPosted: Mon May 14, 2012 7:19 pm     Reply with quote
Got it fixed after posting changed from char rom to char const and fixed my portb it should be port_b issue in the main code.
jrugar
New Version of Code
PostPosted: Tue May 15, 2012 1:24 am     Reply with quote
Use this code to help learn and make better things from it i am giving this version to the public to have fun with and learn.
 * (c)2012 Joe Rugar                                                          *
 * Pic16f628a LED sequence flasher v1.0                                       *
 *   This program is free software: you can redistribute it and/or modify     *
 *   it under the terms of the GNU General Public License as published by     *
 *   the Free Software Foundation, either version 3 of the License, or        *
 *   (at your option) any later version.                                      *
 *   This program is distributed in the hope that it will be useful,          *
 *   but WITHOUT ANY WARRANTY; without even the implied warranty of           *
 *   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the            *
 *   GNU General Public License for more details.                             *
 *   You should have received a copy of the GNU General Public License        *
 *   along with this program.  If not, see <http://www.gnu.org/licenses/>.    *
#use standard_io(b)
#byte port_b = 6
char const led_tab[] =  {0b00000000,0b11111111,0b00000000,0b11111111,0b00000000,0b11111111,0b00000000,0b11111111,
                         0b00000001,0b00000010,0b00000100,0b00001000,0b00010000,0b00100000,0b01000000,0b10000000,
                         0b10000000,0b01000000,0b00100000,0b00010000,0b00001000,0b00000100,0b00000010,0b00000001,
                         0b10000001,0b11000011,0b11100111,0b11111111,0b11111111,0b11100111,0b11000011,0b10000001,
                         0b00011000,0b00111100,0b01111110,0b11111111,0b11111111,0b01111110,0b00111100,0b00011000,
                         0b10011001,0b01100110,0b10011001,0b01100110,0b10011001,0b01100110,0b10011001,0b01100110,
                         0b11001100,0b00110011,0b11001100,0b00110011,0b00110011,0b11001100,0b00110011,0b11001100,
                         0b11000011,0b00111100,0b00111100,0b11000011,0b00111100,0b11000011,0b11000011,0b00111100,
                         0b11000011,0b00111100,0b00111100,0b11000011,0b00111100,0b11000011,0b11000011,0b00111100};
void seq1(void);
void seq2(void);
void seq3(void);
void seq4(void);
void seq5(void);
void  main(void)
      port_b = 0; /* initialize All port_b outputs to be zero */
      while( TRUE )
        seq1();
        seq2();
        seq3();
        seq4();
        seq5();
void seq1(void)
   char i;
   for(i=0; i<96; i++)
      port_b = led_tab[i];
      delay_ms(50);
void seq2(void)
   char i;
   for(i=0; i<96; i++)
void seq3(void)
   char i;
   for(i=0; i<96; i++)
      delay_ms(70);
void seq4(void)
char i;
   for(i=0; i<96; i++)
      delay_ms(80);
void seq5(void)
   char i;
   for(i=0; i<96; i++)
      delay_ms(30);
dyeatman
PostPosted: Tue May 15, 2012 5:40 am     Reply with quote
Thanks Joe! I am sure it will be beneficial to some of the folks here and
future visitors. Maybe a copy could be put in the Code Library?
Google and Forum Search are some of your best tools!!!!
