Two interrupt problems
SuperDave
PostPosted: Mon May 07, 2012 9:08 pm     Reply with quote
Two problems (Version 4.130)
First:
I have a short nonsense program where this compiles
#INT_timer0   //
void EnableLines() {    //
  bCActive = rEnC;
but this produces the error
Error 7 "SpiTest.c" Line 125(9,10): Invalid Pre-Processor directive
#INT_RA   //   ONLY CHANGE IS TIMER0 TO RA
  bCActive = rEnC;
Why the error? How do I get rid of it?
Second:
Port A will actually have three independent pins interrupting on a high to low change. My reading the PICC manual and the 16F1828 manual leave me perplexed. As I see it I have to enable each of them like this
Enable_Interrupts (INT_RA1_H2L | INT_RA2_H2L | INT_RA3_H2L); Then within the int routine what's the best way to separate them? Do I have to test the individual bits of the interrupt register?
PostPosted: Mon May 07, 2012 9:35 pm     Reply with quote
Always post a test program. I made one and it doesn't fail:
Build Successful.
Loaded C:\Program Files\PICC\Projects\PCM_Test\PCM_TEST.cof.
BUILD SUCCEEDED: Mon May 07 20:35:24 2012
CCS PCM C Compiler, Version 4.130, xxxxx 07-May-12 20:35
#include <16F1828.H>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
int8 bCActive;
int8 rEnC;
#INT_RA
  bCActive = rEnC;
SuperDave
PostPosted: Tue May 08, 2012 6:26 am     Reply with quote
OK, thanks, late night typo was the problem. My include spec'd a 16F1826, not 1828 the correct part. The 1826 doesn't allow RA.
So, now the second problem restated. The 16F1828.h file includes these two lines one after the other
#define INT_RA                    0x30FF0B08
#define INT_RA0                   0x30010B08
This compiles
#INT_RA      //port A change interrupt handler
void MyTestPgm() (
  //stuff
This doesn't
#int_RA0   //port A bit0
void MyTestPgm() (
  //stuff
I sort of get it that the two seem to be used differently even though they are in the same section of the include. So I use RA0 in the enable_int and RA to identify the interrupt handler. But if I want multiple bits from Port A, what is the best way to separate them in the handler? Nothing I find seems to deal with that.
Thanks again,
Dave
PostPosted: Tue May 08, 2012 9:56 am     Reply with quote
Dave, 'somewhere' maybe the onscreen help files ?, CCS shows how to access individual bits of PORTB high nibble (b7..b4).
That code does work, I've used it on several projects.
hth
jay
PostPosted: Tue May 08, 2012 5:58 pm     Reply with quote
This compiles
#INT_RA
void MyTestPgm() (
//stuff
That's the correct way to invoke the #INT_RA interrupt.
Ttelmah's post shows how to enable interrupts for multiple pins:
http://www.ccsinfo.com/forum/viewtopic.php?t=45432&start=6
