ccs and MPlab
nidal
ccs and MPlab
PostPosted: Mon Apr 02, 2012 2:54 am     Reply with quote
Hello
I am using ccs 4.124 with mplab.
Later on when building a project the header files were automatically loaded to the project window under header files. But now it does not load them to the project. I have to add them manually.
Could you guide me please ?
Thank you
nidal
PostPosted: Mon Apr 02, 2012 11:35 pm     Reply with quote
Any Help ?
dezso
PostPosted: Mon Apr 02, 2012 11:44 pm     Reply with quote
is it mplabx? or 8
I'm could be wrong many time's, at least I know what I'm doing Smile
nidal
PostPosted: Tue Apr 03, 2012 12:39 am     Reply with quote
MPLAB 8.84
Thank you
Battery David
PostPosted: Tue Apr 03, 2012 8:05 am     Reply with quote
Nidal,
When I use MPLab with CCS I still use very old-school methods. My root.c file has this at the top:
#include   <18F26K20.h>
#include "C:\_Data\PIC\PIC18F26K20_registers.h"
#include "C:\_Data\PIC\PIC18_SFR.h"
#include "Root.h"
#include "ISRs.c"
#include "Initialize.c"
#include "Control.c"
Then, each of the .c files has its own header file.
I know there are different ways of doing this and they may be more efficient but this works for me and I don't have to worry if MPLab has changed.
nidal
PostPosted: Wed Apr 04, 2012 4:36 am     Reply with quote
thank you ;
i am using the same thing.. for example in am including the header of the pic that i use ; but in the last version after compiling the headers appears in the project window of the project in MPLAB ; but now after compiling nothhing appear ; i have to go to the PICC folder then devices then i add it manually to the the project window of MPLAB under headers .
jeremiah
PostPosted: Wed Apr 04, 2012 6:27 am     Reply with quote
You might consider asking in the MPLAB forums since the issue is with the IDE and not the CCS compiler (which is what these forums focus on). I've never run into the problem you describe or I would provide help. Unfortunately, I have no idea how to fix it. Check the MPLAB forums for IDE support.
PostPosted: Wed Apr 04, 2012 4:15 pm     Reply with quote
It's caused by the CCS compiler. It started with vs. 4.120. For that
version and higher, MPLAB doesn't automatically put the PIC header file
into the Header Files list in the Project Window.
I didn't see any notes about it in the readme.txt file. It's just another
unannounced change.
nidal
PostPosted: Thu Apr 05, 2012 5:08 am     Reply with quote
Thank you,
Nothing to do. I have to add them manually.
I would like to ask about my version and MPLABX. It seems it does not work with mplabx. Could you confirm please ? and if yes what kind of settings I need to do ?
Regards
Battery David
PostPosted: Thu Apr 05, 2012 6:59 am     Reply with quote
I tried using MPLabX but, when I found out that it couldn't tolerate spaces in file names or directory paths, I went back to old-fashioned MPLab. This was a shock since spaces have been allowed since 1995!
All I do is gripe!
David
