12F1840 & Touchpad Library
longos
PostPosted: Tue Mar 27, 2012 4:47 am     Reply with quote
I try to use TOUCHPAD library with 12F1840. When I use only PIN_A2 all is OK, but when I declare
#USE TOUCHPAD(RANGE=H, THRESHOLD=6, SCANTIME=32, PIN_A2='A', PIN_A4='B')
Touch buttons doesn't works. Compiler 4.130. Source code:
#include <12LF1840.h>
#include <regPIC12LF1840.h>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES WDT_SW                   //No Watch Dog Timer, enabled in Software
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#use delay(clock=16000000)
#use FIXED_IO( A_outputs=PIN_A0)
#define LED   PIN_A0
#USE TOUCHPAD(RANGE=H, THRESHOLD=15, SCANTIME=32, PIN_A2='B')
//#USE TOUCHPAD(RANGE=H, THRESHOLD=6, SCANTIME=32, PIN_A2='B', PIN_A4='A')
char c;
void main(void){
   setup_oscillator(OSC_16MHZ|OSC_NORMAL|OSC_PLL_OFF,0);
   touchpad_state(1);
   while(1){
       c = TOUCHPAD_GETC();
      if(c == 'B' || c=='A'){
         c=0;
         output_toggle(LED);
         output_toggle(PIN_A4);
I think there's some bug in CCS library. Some ideas ?
PostPosted: Tue Mar 27, 2012 1:22 pm     Reply with quote
void main(void){
c=0;
output_toggle(LED);
You are toggling Pin A4. That's the same pin that you assigned as
a Touchpad input. Don't toggle a pin that is used for the touchpad.
Don't do anything to it. It's controlled by the Touchpad library code.
longos
PostPosted: Wed Mar 28, 2012 3:55 am     Reply with quote
This line is in comment. I use only PIN_A2.
