longos
12F1840 & Touchpad Library |
Posted: Tue Mar 27, 2012 4:47 am |
I try to use TOUCHPAD library with 12F1840. When I use only PIN_A2 all is OK, but when I declare
#USE TOUCHPAD(RANGE=H, THRESHOLD=6, SCANTIME=32, PIN_A2='A', PIN_A4='B')
Touch buttons doesn't works. Compiler 4.130. Source code:
#include <12LF1840.h>
#include <regPIC12LF1840.h>
#FUSES WDT_SW //No Watch Dog Timer, enabled in Software
#use delay(clock=16000000)
#use FIXED_IO( A_outputs=PIN_A0)
#define LED PIN_A0
#USE TOUCHPAD(RANGE=H, THRESHOLD=15, SCANTIME=32, PIN_A2='B')
//#USE TOUCHPAD(RANGE=H, THRESHOLD=6, SCANTIME=32, PIN_A2='B', PIN_A4='A')
char c;
void main(void){
setup_oscillator(OSC_16MHZ|OSC_NORMAL|OSC_PLL_OFF,0);
touchpad_state(1);
while(1){
c = TOUCHPAD_GETC();
if(c == 'B' || c=='A'){
c=0;
output_toggle(LED);
output_toggle(PIN_A4);
I think there's some bug in CCS library. Some ideas ? |
Posted: Tue Mar 27, 2012 1:22 pm |
void main(void){
c=0;
output_toggle(LED);
You are toggling Pin A4. That's the same pin that you assigned as
a Touchpad input. Don't toggle a pin that is used for the touchpad.
Don't do anything to it. It's controlled by the Touchpad library code. |
longos
Posted: Wed Mar 28, 2012 3:55 am |
PCM programmer wrote: | Quote: |
You are toggling Pin A4. | This line is in comment. I use only PIN_A2. |
