haqamar
16f883 config fuses problem |
Posted: Wed Jan 25, 2012 1:39 pm |
Unable to set the fuses properly for 16f883 in ccs ver 4.110. Is this correct format ?
#include <16f883.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, NOPUT
#use delay(oscillator=20M)
After compilation I see EC_IO instead of external HS oscillator...
plzz help |
Posted: Wed Jan 25, 2012 3:37 pm |
#include <16f883.h>
#use delay(clock=20M)
The keywords 'crystal', and 'oscillator' in use delay, override the fuse selection, instead using the crystal or internal oscillator respectively.
Don't put extra spaces between the 'use' and the 'delay' on some compiler versions this will cause problems.
haqamar
Posted: Wed Jan 25, 2012 4:11 pm |
thanx for pointing 'clock' |
