16f883 config fuses problem
haqamar
PostPosted: Wed Jan 25, 2012 1:39 pm     Reply with quote
Unable to set the fuses properly for 16f883 in ccs ver 4.110. Is this correct format ?
#include <16f883.h>
#fuses   HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, NOPUT
#use     delay(oscillator=20M)
After compilation I see EC_IO instead of external HS oscillator...
plzz help
PostPosted: Wed Jan 25, 2012 3:37 pm     Reply with quote
#include <16f883.h>
#use delay(clock=20M)
The keywords 'crystal', and 'oscillator' in use delay, override the fuse selection, instead using the crystal or internal oscillator respectively.
Don't put extra spaces between the 'use' and the 'delay' on some compiler versions this will cause problems.
haqamar
PostPosted: Wed Jan 25, 2012 4:11 pm     Reply with quote
thanx for pointing 'clock' Smile
