PICoHolic
Software-based calendar (RTC) |
Posted: Thu Mar 26, 2009 7:30 am |
Here's a software-based calendar. Timer 1 is fed from an external 32.768 KHz crystal.
The calendar will still run in sleep mode.
Any comments/modifications/enhancements are welcome!
#ifndef CALENDAR_H
#define CALENDAR_H
#define EnableCalendar() enable_interrupts(INT_TIMER1)
#define DisableCalendar() disable_interrupts(INT_TIMER1)
const char DaysStr[7][5] = {"SUN\0", "MON\0", "TUE\0", "WED\0", "THU\0", "FRI\0", "SAT\0"};
const char MonthsStr[12][4]= {"JAN", "FEB", "MAR", "ARP", "MAY", "JUN", "JUL",
"AUG", "SEP", "OCT", "NOV", "DEC"};
#define IS_LEAP(year) (year%4 == 0)
#define AM 0
#define PM 1
#define H_12 0
#define H_24 1
typedef struct _calendar {
int8 Seconds;
int8 Minutes;
int8 Hours;
int8 DayOfWeek;
int8 Day;
int8 Month;
int8 Year;
int1 H_12_24;
int1 AM_PM;
}Calendar;
Calendar MyCalendar;
void IncrementDate(void)
MyCalendar.DayOfWeek = (MyCalendar.DayOfWeek % 7) + 1; //increment day of week
MyCalendar.Day++; //increment day
if ( (MyCalendar.Day == 29 && MyCalendar.Month==2 && !IS_LEAP(MyCalendar.Year))
|| (MyCalendar.Day == 30 && MyCalendar.Month==2)
|| (MyCalendar.Day == 31 && (MyCalendar.Month==4 || MyCalendar.Month==6
|| MyCalendar.Month==9 || MyCalendar.Month==11 ))
|| (MyCalendar.Day == 32) )
MyCalendar.Day=1;
if(++MyCalendar.Month == 13)
MyCalendar.Month=1;
MyCalendar.Year++;
void IncrementTime(void)
if (++MyCalendar.Seconds == 60) //increment seconds
MyCalendar.Seconds = 0; //clear seconds
if (++MyCalendar.Minutes == 60) //increment minutes
MyCalendar.Minutes = 0; //clear minutes
if (MyCalendar.H_12_24 == H_12) //12 hours
if (++MyCalendar.Hours == 13)
MyCalendar.Hours = 1;
if (MyCalendar.AM_PM == AM)
IncrementDate();
else if (MyCalendar.Hours == 12)
MyCalendar.AM_PM ^= 1;
else //24 hours
if (++MyCalendar.Hours == 24)
MyCalendar.Hours = 0;
IncrementDate();
int1 Sflg;
#int_TIMER1 //Real Time Clock
void TIMER1_isr()
Bit_Set(TMR1H,7);
Sflg=true;
IncrementTime();
//one sec toggle
//#ASM btg PORTD, 4 #ENDASM
void delay_s(int8 s)
while(s--)
Sflg = false;
while(!Sflg);
void init_Calendar()
MyCalendar.Seconds = 00;
MyCalendar.Minutes = 00;
MyCalendar.Hours = 12;
MyCalendar.DayOfWeek = 5; //Thursday
MyCalendar.Day = 1; //1st
MyCalendar.Month = 1; //Jan
MyCalendar.Year = 9; //2009
MyCalendar.H_12_24 = H_12; //12 hours
MyCalendar.AM_PM = AM; //AM
bit_clear(T1CON,7);
EnableCalendar();
Posted: Wed Jan 11, 2012 4:47 pm |
Code: | const char DaysStr[7][5] = {"SUN\0", "MON\0", "TUE\0", "WED\0", "THU\0", "FRI\0", "SAT\0"}; | Quoted strings will be zero terminated by the compiler so this line can be simplified to: Code: | const char DaysStr[7][4] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"}; | Or, remove the whole line as it isn't used.
MonthsStr[] isn't used either and can be removed too. Strange but here you have not added the extra terminating zero, so why did you do it to the other line?
Code: | //one sec toggle
//#ASM btg PORTD, 4 #ENDASM | Easier to read and higher portability: Code: | //one sec toggle
//output_toggle(PIN_D4); |
Code: | void delay_s(int8 s)
while(s--)
Sflg = false;
while(!Sflg);
} | Why bother to create your own blocking delay function? The CCS delay_ms() is not perfect, but your delay_s function is not synchronized to the interrupt and can be as far off as 0.99999 seconds. Then I rather use the delay_ms function which is accurate up to a few microseconds. |
