Does #elif work as intended
picnic
PostPosted: Wed Dec 28, 2011 11:18 am     Reply with quote
A
#ifdef WIBBLE
only requires that WIBBLE be defined, can be 0 or any other value
If you try a
#elif WIBBLE
the following code is not included if WIBBLE is defined as 0, it's OK with 1
Seeing as the #ifdef only required the definition to exist without any care for its value it seems logical the the #elif would behave the same way.
Try
void main() {
   int i;
#ifdef OPT1
   i = 10;
#endif
#ifdef OPT2
   i = 20;
#elif OPT1
   i = 11;
#else
   i = 30;
#endif
if #OPT1="0" is included in the compilation command the i=11 does not compile (the i=10 is fine), with #OPT1="1" both pieces of code compile.
Compiler version is 4.128 and I'm targeting a 18F46K22 if it makes any difference.
SherpaDoug
PostPosted: Wed Dec 28, 2011 11:33 am     Reply with quote
I think elif goes with if. To go with ifdef you would want elifdef which I have never seen.
picnic
PostPosted: Wed Dec 28, 2011 11:49 am     Reply with quote
I like your thinking, the example in the help though is
#IFDEF  id
   code
#ELIF
   code
#ELSE
   code
#ENDIF
which makes no sense (as there is no condition for the #elif) but does imply #elif is for #ifdef Confused
Right just tried your idea. No compiler errors using #elifdef but the i=11 doesn't get compiled for OPT=1 or OPT=0 so appears to be worse.
FvM
PostPosted: Wed Dec 28, 2011 1:41 pm     Reply with quote
As far as I see is the CCS implementation of preprocessor if-section compliant to the C language standard.
There's no elifdef provided in the standard.
The misleading help file examples should be in fact corrected.
The logical way for alternative options in conditional compilation is to use non-zero constant expressions, I think.
They can be queried with #if #elif #else #endif.
bkamen
PostPosted: Wed Dec 28, 2011 5:46 pm     Reply with quote
i think
#ELIF defined(someDefine)
or
#ELIF !defined(someDefine)
Should work.
-Ben
