Gabriel
Array Assignment on the fly? - SOLVED |
Posted: Wed Dec 07, 2011 7:07 am |
I want to know how can i initialize an array without resorting to loops.
i have a data set like:
when i declare my array:
Code: | Int Device[4]={243, 14, 25, 39}; |
its all good..
But if later down the code i want to "Device[]" to have diferent values
what would be the _working_ equivalent of this:
Code: | Device[]={155, 26, 35, 49}; |
The values in each possition of "Device[]" change depending on the function called...
So far my solution has been to declare several:
Code: | Const Int Temp1[4]={1,2,3,4} ....
Const Int Temp2[].... |
arrays with the values i want, and then:
Code: | STRCPY(Device, Temp1);...
STRCPY(Device, Temp2);... |
Depending on which function needs to use Device[]...
The actual size of Device is [75].
is there a better way? _________________ CCS PCM 5.078 & CCS PCH 5.093
FvM
Posted: Wed Dec 07, 2011 1:18 pm |
strcpy() is for null-terminated strings, use memcpy() for arbitrary data. |
Gabriel
Posted: Fri Dec 09, 2011 7:37 am |
hey guys,
Thanks for your replies...
I see I was not too far off...
STRCPY is working for me right now, however I will change to MEMCPY.
Thanks!
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
