Array Assignment on the fly? - SOLVED
Gabriel
PostPosted: Wed Dec 07, 2011 7:07 am     Reply with quote
I want to know how can i initialize an array without resorting to loops.
i have a data set like:
{243, 14, 25, 39}
when i declare my array:
Int Device[4]={243, 14, 25, 39};
its all good..
But if later down the code i want to "Device[]" to have diferent values
what would be the _working_ equivalent of this:
Device[]={155, 26, 35, 49};
The values in each possition of "Device[]" change depending on the function called...
So far my solution has been to declare several:
Const Int Temp1[4]={1,2,3,4} ....
Const Int Temp2[]....
arrays with the values i want, and then:
STRCPY(Device, Temp1);...
STRCPY(Device, Temp2);...
Depending on which function needs to use Device[]...
The actual size of Device is [75].
is there a better way?
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Wed Dec 07, 2011 1:18 pm     Reply with quote
strcpy() is for null-terminated strings, use memcpy() for arbitrary data.
PostPosted: Wed Dec 07, 2011 1:49 pm     Reply with quote
See this previous thread on the topic:
http://www.ccsinfo.com/forum/viewtopic.php?t=29142
Gabriel
PostPosted: Fri Dec 09, 2011 7:37 am     Reply with quote
hey guys,
Thanks for your replies...
I see I was not too far off...
STRCPY is working for me right now, however I will change to MEMCPY.
Thanks!
G.
