4x4 matrix keypad with interrupts
delene
PostPosted: Mon Nov 07, 2011 7:31 am     Reply with quote
Hi
I have a 4x4 keypad connected to portb with the pull ups enabled. Previously I had been checking the keypad in my main code, but now would like to change my code to use interrupts rather.
I tried int_rb, but couldn't come right
I then tried int_rtcc - and didn't come right.
I now have timer1 enabled and it is occassionally reading the keypad.
Is this the best way of trying to read the keypad through interrupts?
I am using a pic18f4523
My crystal is 20MHz
and timer1 is setup as follows
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);      //26.2 ms overflow
Many thanks
Delene
dyeatman
PostPosted: Mon Nov 07, 2011 8:23 am     Reply with quote
In Search enter the three words: keypad, matrix and interrupts then set to "Search for All terms" and you will find this:
http://www.ccsinfo.com/forum/viewtopic.php?t=40982&
Google and Forum Search are some of your best tools
PostPosted: Mon Nov 07, 2011 1:12 pm     Reply with quote
This thread has sample code for polling the keypad every 10ms inside
the Timer0 interrupt routine:
http://www.ccsinfo.com/forum/viewtopic.php?t=45935
delene
PostPosted: Mon Nov 07, 2011 11:54 pm     Reply with quote
Thanks Everyone
I eventually came right. I used this code
http://www.ccsinfo.com/forum/viewtopic.php?t=19726
