I have a 4x4 keypad connected to portb with the pull ups enabled. Previously I had been checking the keypad in my main code, but now would like to change my code to use interrupts rather.
I tried int_rb, but couldn't come right
I then tried int_rtcc - and didn't come right.
I now have timer1 enabled and it is occassionally reading the keypad.
Is this the best way of trying to read the keypad through interrupts?
I am using a pic18f4523
My crystal is 20MHz
and timer1 is setup as follows
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); //26.2 ms overflow
Many thanks
Delene
dyeatman
Posted: Mon Nov 07, 2011 8:23 am
In Search enter the three words: keypad, matrix and interrupts then set to "Search for All terms" and you will find this:
