pretyh8machin
ADC / Keypad help |
Posted: Mon Nov 07, 2011 1:56 am |
Hey CCS forum users,
So I have been working on this project for class where I have to control the direction of a motor using a H-bridge circuit connected to with my PIC. I have a keypad that input that changes these values just fine. I broke down my code into sections so I can determine where I am getting any errors or problems with the code. I got my ADC to display a value on my LCD too so I know my ADC is working fine also. For some reason when I combined the code altogether I found out that as soon as I initialized my adc converter my keypad stopped responding. I couldn't figure out why. Heres my code:
#include <18f4580.h>
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP, HS, MCLR
#use delay(clock=8000000)
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
#include <flex_kbd.c>
#include <flex_lcd.c>
#define BRAKE PIN_C4
#define DIRECTION PIN_C5
//!#int_rda
//!void rda_isr(void)
//! lcd_init(); // Always call this first.
//! kbd_init();
//! long value1;
//! setup_port_a(ALL_ANALOG);
//! setup_adc(adc_clock_internal);
//! setup_ccp1(CCP_PWM);
//! setup_timer_2(T2_DIV_BY_1, 127, 1);
//! set_adc_channel(0);
//! delay_us(10);
//! value1=read_adc();
//! lcd_gotoxy(1, 1);
//! printf(lcd_putc,"\f%2X ", value1);
//! set_pwm1_duty(value1);
//! delay_ms(100);
void housekeeping();
void startmenu();
void optionbegin();
void displaybegin();
void menudisplay();
void operation();
void adc();
long value1;
housekeeping();
//enable_interrupts(INT_RDA);
//enable_interrupts(GLOBAL);
//startmenu();
//menudisplay();
//adc();
operation();
void housekeeping(){
kbd_init();
output_high (BRAKE);
void startmenu(){
displaybegin();
optionbegin();
void displaybegin(){
lcd_putc( "\fPress 1 to begin");
void optionbegin(){
char enter;
int i=0;
while (i!=1){
enter=kbd_getc();
if (enter=='1') {
i=1;
} else {
i=0;
void menudisplay(){
int i;
lcd_gotoxy(1, 1);
lcd_putc( "\fPress '1'\n");
lcd_gotoxy(1, 2);
lcd_putc( "to start brake");
lcd_gotoxy(16, 2);
for(i = 0; i < 20; i++)
printf(lcd_putc," \b\b");
delay_ms(150);
lcd_gotoxy(16, 1);
delay_ms(150);
lcd_gotoxy(1, 1);
lcd_putc( "\fPress '2'\n");
lcd_gotoxy(1, 2);
lcd_putc( "to stop brake");
lcd_gotoxy(16, 2);
delay_ms(150);
lcd_gotoxy(16, 1);
delay_ms(150);
lcd_gotoxy(1, 1);
lcd_putc( "\f'3' and '4'\n");
lcd_gotoxy(1, 2);
lcd_putc( "change direction");
lcd_gotoxy(16, 2);
delay_ms(150);
lcd_gotoxy(16, 1);
delay_ms(150);
void operation(){
char k;
//! lcd_putc( "\fPress '1'\n");
while (TRUE){
k=kbd_getc();
if(k!=0){
if(k=='2')
output_low (BRAKE);
if(k=='1')
if(k=='4')
output_low (DIRECTION);
if(k=='3')
output_high (DIRECTION);
void adc(){
I commented out the irrelevant sections because thats just a menu display. Any help is appreciated. Thnx in advance. The Keypad works up until I initialize the ADC. |
Posted: Mon Nov 07, 2011 3:22 am |
The 'key thing' you have not shown, is the start of the flex_kbd driver, defining which pins are used for the keypad.
Don't initialise the ADC at multiple places. Do it _once_, either at the start of main, or in an init routine. Then 'think'. What ADC pins are you using? (again you don't say). Does it make sense to setup _all_ the ADC pins (on your chip that means AN0 to AN10, the whole of portA, and B0,B1 & B4). If any of these pins are are used as digital inputs, they _won't_ function after this is done....
I'd guess at least one of these pins is being used for the keypad....
Since you only seem to be reading AN0, use
setup_adc_ports(AN0);
Also, at your clock rate, ADC_CLOCK_INTERNAL, is _not_ recommended look at table 19-1 in the data sheet, and use:
setup_adc(ADC_CLOCK_DIV_16);
