Pointer to struct
E_Blue
Pointer to struct
PostPosted: Mon Sep 12, 2011 9:48 am     Reply with quote
I have the following function to write to an external SPI EEPROM.
void FillBufferEE(long StartAddress, char *DataBuffer, char ByteCount)
    #warning "Esta funcion no controla desbordamientos de buffer; el buffer debe tener suficiente espacio para la cantidad de datos solicitados"
    char x;
    while(EE_Busy())
            delay_us(10);
        output_low(CS);
        spi_write(Read);
        spi_write(make8(StartAddress,1));
        spi_write(make8(StartAddress,0));
        for(x=0;x<ByteCount;x++)
            DataBuffer[x]=spi_read(0);
        output_high(CS);
And I think maybe I should declare it
void FillBufferEE(long StartAddress, char *DataBuffer[], char ByteCount)
I'm calling the function in many program points and is working OK but when I call the function and pass as a destination buffer a 32bit UInteger inside an struct did'nt work, It seems like doing nothing.
FillBufferEE(Timer1EE,Timer1.Setting,4);
Electric Blue
RF_Developer
Re: Pointer to struct
PostPosted: Mon Sep 12, 2011 10:16 am     Reply with quote
You need to pass the *address* of Timer1.Setting. You are passing its value, which will be interpreted as an pointer, with wrong results. You need the & operator:
FillBufferEE(Timer1EE,&Timer1.Setting,4);
If you wanted to fill an array you could write
FillBufferEE(Timer1EE,My_Array,4);
or
FillBufferEE(Timer1EE,&My_Array[0],4);
both should produce the same result. An array name without [] *is* a pointer in C. To pass a pointer to a specfic array element you need the & just as for a simple variable whether its in a struct or not.
RF Developer
E_Blue
Pointer to struct
PostPosted: Mon Sep 12, 2011 12:04 pm     Reply with quote
Thanks!, that works pretty well. Wink
Electric Blue
