E_Blue
Pointer to struct |
Posted: Mon Sep 12, 2011 9:48 am |
I have the following function to write to an external SPI EEPROM.
Code: | void FillBufferEE(long StartAddress, char *DataBuffer, char ByteCount)
#warning "Esta funcion no controla desbordamientos de buffer; el buffer debe tener suficiente espacio para la cantidad de datos solicitados"
char x;
while(EE_Busy())
delay_us(10);
output_low(CS);
spi_write(Read);
spi_write(make8(StartAddress,1));
spi_write(make8(StartAddress,0));
for(x=0;x<ByteCount;x++)
DataBuffer[x]=spi_read(0);
output_high(CS);
And I think maybe I should declare it
Code: | void FillBufferEE(long StartAddress, char *DataBuffer[], char ByteCount) |
I'm calling the function in many program points and is working OK but when I call the function and pass as a destination buffer a 32bit UInteger inside an struct did'nt work, It seems like doing nothing.
Code: | FillBufferEE(Timer1EE,Timer1.Setting,4); |
_________________ Electric Blue |
RF_Developer
Re: Pointer to struct |
Posted: Mon Sep 12, 2011 10:16 am |
E_Blue wrote: | I have the following function to write to an external SPI EEPROM.
Code: | void FillBufferEE(long StartAddress, char *DataBuffer, char ByteCount) |
You need to pass the *address* of Timer1.Setting. You are passing its value, which will be interpreted as an pointer, with wrong results. You need the & operator:
Code: | FillBufferEE(Timer1EE,&Timer1.Setting,4); |
If you wanted to fill an array you could write
Code: | FillBufferEE(Timer1EE,My_Array,4); |
or
Code: | FillBufferEE(Timer1EE,&My_Array[0],4); |
both should produce the same result. An array name without [] *is* a pointer in C. To pass a pointer to a specfic array element you need the & just as for a simple variable whether its in a struct or not.
RF Developer |
E_Blue
Pointer to struct |
Posted: Mon Sep 12, 2011 12:04 pm |
Thanks!, that works pretty well. _________________ Electric Blue |
