| View previous topic :: View next topic   |
			nehallove
				| Boot Block Table Read protection makes code non-functional |
				 Posted: Wed Aug 24, 2011 12:40 pm     |
				Hi everyone,
We are using PIC18F25K20 processor. We have our code size 96% of ROM and 31% of RAM. We ask Microchip to program our CCS code. In their configuration bit setting we put Boot Block Table Read Protection Enable. After doing that our code doesn't work, if you remove that setting then it works. Microchip came back to us and asked if our code is writing in that area which we don't. Is there anyway to find out if on these locations we can not write? How we can debug the issue?
Any help will be appreciated.
nehal _________________ nehal |
				 Posted: Wed Aug 24, 2011 1:03 pm     |
				Edit the 18F25K20.h file and comment out the line where it says #nolist,
as shown below.
 	  | Quote: | 	 		  //////// Standard Header file for the PIC18F25K20 device #device PIC18F25K20
//#nolist
//////// Program memory: 16384x16  Data RAM: 1536  Stack: 31
//////// I/O: 25   Analog Pins: 13
//////// Data EEPROM: 256
//////// C Scratch area: 00   ID Location: 200000
Compile your program and then search the .LST file for this word:
			nehallove
				 Posted: Wed Aug 24, 2011 1:19 pm     |
				What we found that we have some TBLRD instructions which we use for the constants we defined. Does that affect? Does that store something on the BOOT Block Table Read Protection Area?
Thank you.
				 Posted: Wed Aug 24, 2011 3:06 pm     |
				Are any of the TBLRD instructions attempting to read the address range
(000h-7FFh) of the Boot Block area ? |
			nehallove
				 Posted: Wed Aug 24, 2011 7:00 pm     |
				which instruction i am looking at ?
....................        temp1=(float)(temp_tbl[i])*10;
257A:  BCF    FD8.0
257C:  RLCF   x26,W
257E:  CLRF   03
2580:  MOVFF  FF2,22F
2584:  BCF    FF2.7
2586:  MOVLB  0
2588:  CALL   023C
258C:  TBLRD*+
258E:  MOVFF  FF5,03
2592:  MOVLB  2
2594:  BTFSC  x2F.7
2596:  BSF    FF2.7
2598:  MOVLB  3
259A:  MOVWF  x7E
259C:  MOVFF  03,37F
25A0:  MOVLB  0
25A2:  CALL   101C
25A6:  MOVFF  00,230
25AA:  MOVFF  01,231
25AE:  MOVFF  02,232
25B2:  MOVFF  03,233
25B6:  MOVFF  03,39D
25BA:  MOVFF  02,39C
25BE:  MOVFF  01,39B
25C2:  MOVFF  00,39A
25C6:  MOVLB  3
25C8:  CLRF   xA1
25CA:  CLRF   xA0
25CC:  MOVLW  20
25CE:  MOVWF  x9F
25D0:  MOVLW  82
25D2:  MOVWF  x9E
25D4:  MOVLB  0
25D6:  CALL   15A4
25DA:  MOVFF  03,22A
25DE:  MOVFF  02,229
25E2:  MOVFF  01,228
25E6:  MOVFF  00,227
I can not see any instruction which clearly says the locations.
Thanks. _________________ nehal |
			FvM
				 Posted: Thu Aug 25, 2011 12:40 am     |
				It can be expected, that call 023c is a constant load routine, setting TBLPTR to a succeeding memory location. In this case TBLRD*+ will fail, when table read protection is set for the boot block.
 	  | Code: | 	 		  2588: CALL 023C
258C: TBLRD*+  |
Generally, this kind of boot block protection only makes sense, if the boot block is exclusively reserved to the boot loader. Obviously this isn't the case in your application. |
			nehallove
				 Posted: Fri Aug 26, 2011 1:05 pm     |
				Thank you very much for the help.
