What's happening with my code protection??
cerr
PostPosted: Wed Jul 13, 2011 12:00 pm     Reply with quote
Hi There,
I'm seeing odd things with my code protection.
I am using #fuses PROTECT in my code to enable code protection on my pic18f86k22.
I however am still able to read out the code with PICkit3. And when i look at CONFIG5L, it is set to 0x02. But I believe it ought to be 0x00. Is it safe to set it to 0 from within my code? Why isn't this done correctly by my app?
Also, CONFIG5H is set to 0x30 and I'm wondering why as bit 4 and 5 are Unimplemented bit, read as ‘0 - any clues?
Thank you!
PostPosted: Wed Jul 13, 2011 12:10 pm     Reply with quote
Silly question but are you really reading the PIC and not just seeing the 'ghost' program from your last session?
Sure test is to bootup MPLAB,do NOT load ANY projects and then read the device to confirm you're really reading from it.
I've been fooled before.....
cerr
Even after setting CONFIG5L and CONFIG5H to 0, I'm able to read out the memory properly with my Pickit. Also after setting both to 0, CONFIG5H still reads 0x30...
cerr
PostPosted: Wed Jul 13, 2011 12:19 pm     Reply with quote
I did exactly this (just used PICKit3 before to read) with MPLAB (new session, no project opened) I read from my chip, after the read i can open the program memory window and it's all there, no protection whatsoever... :(
PostPosted: Wed Jul 13, 2011 2:39 pm     Reply with quote
If you are working from MPLAB, you need to switch out of 'debug' mode here. This setting is the default now, and _overrides_ the fuse settings.
Separately, if you have 'debug' mode selected in the code, this too disables certain fuses (including protection).
cerr
PostPosted: Wed Jul 13, 2011 2:41 pm     Reply with quote
Yep,
code is compiled in Release mode and i'm not using debug either, my fuses look like this:
#case
#device adc=16 HIGH_INTS=TRUE
#fuses WDT256,WDT_SW                //Watch Dog Timer uses 1:65536 Postscale
#fuses HSH                          //Hi-Speed crystal oscillator
#fuses BORV30                  //Brownout reset at 3V tripping level
#fuses NOPLLEN                  //No PLL enabled
#fuses BBSIZ1K                     //1K words Boot Block size
#fuses NOXINST                     //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#fuses PROTECT                  //Enable code protection
#fuses SOSC_DIG
#fuses PUT                     //Enable PowerUpTimer
PostPosted: Wed Jul 13, 2011 3:11 pm     Reply with quote
The PROTECT fuse doesn't protect the Boot Block. That's a separate fuse:
http://www.ccsinfo.com/forum/viewtopic.php?t=42201
cerr
PostPosted: Wed Jul 13, 2011 3:43 pm     Reply with quote
Well yeah but still, I do a
CONFIG5L = 0x00;
CONFIG5H = 0x00;
after i enter my main but still, nothing.... any other clues? I also posted in the Microchip forum...
Thanks!
PostPosted: Wed Jul 13, 2011 4:20 pm     Reply with quote
Post the code necessary to make those two lines compile.
asmallri
PostPosted: Thu Jul 14, 2011 12:27 am     Reply with quote
CONFIG5L = 0x00;
CONFIG5H = 0x00;
Thanks!
If you are using Microchip's IDE then make sure you have the config setting to use the fuses in the code.
Regards, Andrew
