Any one have some sample codes to interface with CF or MMC f
Chen
PostPosted: Wed Feb 05, 2003 12:57 pm     Reply with quote
___________________________
Original Post ID: 11308
chas
Re: Any one have some sample codes to interface with CF or M
PostPosted: Wed Feb 05, 2003 3:37 pm     Reply with quote
Check the link below for an article on the subject.
Original Post ID: 11317
Pete Smith
PostPosted: Thu Feb 06, 2003 2:51 am     Reply with quote
If you do a search on this board for MMC, there have been plenty of questions asked.
Someone (Tomi?) has successfully interfaced a PIC to an MMC card, using it as flat storage. I'm actually working on something similar myself, but implementing FAT16 (very basic) so I can store large amounts (64Mb) of data, and then read it into a PC using a USB reader.
There's also masses of data out there on the 'net about interfacing MMC cards, and a bit on MMC cards to PICs.
HTH
Pete.
Original Post ID: 11335
Tomi
PostPosted: Thu Feb 06, 2003 4:09 am     Reply with quote
I think Chang-Huei Wu did it. See the link below :)
:=I'm actually working on something similar myself, but implementing FAT16 (very basic) so I can store large amounts (64Mb) of data, and then read it into a PC using a USB reader.
Original Post ID: 11336
John
PostPosted: Thu Feb 06, 2003 5:22 am     Reply with quote
Post your e-mail adress and I can mail you the complete files made by C-H Wu based on Tomi's code.
/John
Original Post ID: 11340
Chen
PostPosted: Thu Feb 06, 2003 8:04 am     Reply with quote
Original Post ID: 11346
Chen
Here, thanks!
PostPosted: Thu Feb 06, 2003 8:05 am     Reply with quote
chen@dataq.com
Original Post ID: 11347
Chen
Thanks!
PostPosted: Thu Feb 06, 2003 8:09 am     Reply with quote
Original Post ID: 11352
Re: Any one have some sample codes...
PostPosted: Thu Feb 06, 2003 2:49 pm     Reply with quote
<font face="Courier New" size=-1>:=I think Chang-Huei Wu did it.
That code listing doesn't display properly, because some
"less than" symbols are seen as html tags by this board.
For example, in the mmc_read_flush() function, the "for" loop
is missing several statements. You can see that if you use
your browser to "view document source".
He needs to edit that post, and use the html tags, PRE and /PRE.
These tags allow C code to be posted accurately on this board.
Here are some links on the PRE tag:
<a href="http://www.createafreewebsite.net/html_tutorial/pre_tag.html" TARGET="_blank"> <a href="http://www.createafreewebsite.net/html_tutorial/pre_tag.html" TARGET="_blank">http://www.createafreewebsite.net/html_tutorial/pre_tag.html</a></a>
Here is an online demo that allows you to play around with
the PRE tag and see the results:
<a href="http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_pre" TARGET="_blank"> <a href="http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_pre" TARGET="_blank">http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_pre</a></a>
This board doesn't work exactly like that demo.
This board seems to remove blank lines when you use the PRE tag.
So I have to use the BR tag to put them back in.
</font>
Original Post ID: 11373
Pete Smith
PostPosted: Thu Feb 06, 2003 3:45 pm     Reply with quote
:=I think Chang-Huei Wu did it. See the link below <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=:=I'm actually working on something similar myself, but implementing FAT16 (very basic) so I can store large amounts (64Mb) of data, and then read it into a PC using a USB reader.
Damn! I thought your code was handy (09/09/2002). For some reason, I never saw the last part of this thread (think I was still on holiday).
I'm looking forward to trying this code out! Once I've done that, I just have to write the FAT16 code :-/
I'll share it around once it works though.
Pete.
Original Post ID: 11375
Chang-Huei Wu
MMC for PIC with USB reader
PostPosted: Sat Feb 08, 2003 11:53 pm     Reply with quote
:=I'm looking forward to trying this code out! Once I've done that, I just have to write the FAT16 code :-/
:=I'll share it around once it works though.
:=Pete.
I don't know much about the FAT16, but, FAT16 code might not be necessary, I took the following steps:
1. format the MMC with DOS command for FAT16 and 2048 bytes per cluster
(with MMC in USB reader as removable disk F:)
format F: /FS:FAT /A:2048 /V:MMC_32MB
if you got total a total space of 32,030,720 bytes and 15,640 clusters, then the starting address of your first file will be 0x00013a00
2. copy a dummy file of EXACTLY 1 MB into the MMC, say dummy_1.dat, 1048576 bytes = 2048 x 512 = 0x00100000, then, dummy_1.dat will start from 0x00013a00, and the next file will start from 0x00113a00
3. connect the MMC with you PIC, writing data from 0x00013a00 with the following initiate command, mmc_open_4_write(0x00, 0x01, 0x3a); keep writing upto 1 MB of data.
4. put the MMC back to USB reader, then you can get your data back by simply copy dummy_1.dat back.
That's all.
Best wishes
C-H Wu
Original Post ID: 11439
Richard Rolland
PostPosted: Fri Mar 14, 2003 1:06 pm     Reply with quote
Hi, I am trying to do the same thing using a micro-controller to interface the CF card. I trying to find out the easiest way to create a file and append data to it. Did you have good success?
Original Post ID: 12676
vinash
help needed
PostPosted: Thu Feb 09, 2006 3:01 am     Reply with quote
I am trying to interface a sd card to a micro-controller and implementing FAT16. If some has a code, I would be very grateful, if you could send it to me.My e-mail add is vinash123@hotmail.com.thank you.
PostPosted: Thu Feb 09, 2006 8:09 am     Reply with quote
Use the search function of this forum before posting a question. You will get your answer much quicker and it saves us from reading the same questions over and over again.
subodh
PostPosted: Sun Feb 11, 2007 12:21 am     Reply with quote
/John
Can you send me this code on subodh1978@yahoo.com
Subodh
