Chen Guest
Any one have some sample codes to interface with CF or MMC f |
Posted: Wed Feb 05, 2003 12:57 pm |
___________________________
Original Post ID: 11308 |
chas Guest
Re: Any one have some sample codes to interface with CF or M |
Posted: Wed Feb 05, 2003 3:37 pm |
Check the link below for an article on the subject.
Original Post ID: 11317 |
Pete Smith Guest
Posted: Thu Feb 06, 2003 2:51 am |
If you do a search on this board for MMC, there have been plenty of questions asked.
Someone (Tomi?) has successfully interfaced a PIC to an MMC card, using it as flat storage. I'm actually working on something similar myself, but implementing FAT16 (very basic) so I can store large amounts (64Mb) of data, and then read it into a PC using a USB reader.
There's also masses of data out there on the 'net about interfacing MMC cards, and a bit on MMC cards to PICs.
HTH
Pete.
Original Post ID: 11335 |
Tomi Guest
Posted: Thu Feb 06, 2003 4:09 am |
I think Chang-Huei Wu did it. See the link below :)
:=I'm actually working on something similar myself, but implementing FAT16 (very basic) so I can store large amounts (64Mb) of data, and then read it into a PC using a USB reader.
Original Post ID: 11336 |
John Guest
Posted: Thu Feb 06, 2003 5:22 am |
Post your e-mail adress and I can mail you the complete files made by C-H Wu based on Tomi's code.
/John
Original Post ID: 11340 |
Chen Guest
Thanks |
Posted: Thu Feb 06, 2003 8:04 am |
Original Post ID: 11346 |
Chen Guest
Here, thanks! |
Posted: Thu Feb 06, 2003 8:05 am |
chen@dataq.com
Original Post ID: 11347 |
Chen Guest
Thanks! |
Posted: Thu Feb 06, 2003 8:09 am |
Original Post ID: 11352 |
Re: Any one have some sample codes... |
Posted: Thu Feb 06, 2003 2:49 pm |
<font face="Courier New" size=-1>:=I think Chang-Huei Wu did it.
That code listing doesn't display properly, because some
"less than" symbols are seen as html tags by this board.
For example, in the mmc_read_flush() function, the "for" loop
is missing several statements. You can see that if you use
your browser to "view document source".
He needs to edit that post, and use the html tags, PRE and /PRE.
These tags allow C code to be posted accurately on this board.
Here are some links on the PRE tag:
<a href="http://www.createafreewebsite.net/html_tutorial/pre_tag.html" TARGET="_blank"> <a href="http://www.createafreewebsite.net/html_tutorial/pre_tag.html" TARGET="_blank">http://www.createafreewebsite.net/html_tutorial/pre_tag.html</a></a>
Here is an online demo that allows you to play around with
the PRE tag and see the results:
<a href="http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_pre" TARGET="_blank"> <a href="http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_pre" TARGET="_blank">http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_pre</a></a>
This board doesn't work exactly like that demo.
This board seems to remove blank lines when you use the PRE tag.
So I have to use the BR tag to put them back in.
</font>
Original Post ID: 11373 |
Pete Smith Guest
Posted: Thu Feb 06, 2003 3:45 pm |
:=I think Chang-Huei Wu did it. See the link below <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=:=I'm actually working on something similar myself, but implementing FAT16 (very basic) so I can store large amounts (64Mb) of data, and then read it into a PC using a USB reader.
Damn! I thought your code was handy (09/09/2002). For some reason, I never saw the last part of this thread (think I was still on holiday).
I'm looking forward to trying this code out! Once I've done that, I just have to write the FAT16 code :-/
I'll share it around once it works though.
Pete.
Original Post ID: 11375 |
Chang-Huei Wu Guest
MMC for PIC with USB reader |
Posted: Sat Feb 08, 2003 11:53 pm |
:=I'm looking forward to trying this code out! Once I've done that, I just have to write the FAT16 code :-/
:=I'll share it around once it works though.
:=Pete.
I don't know much about the FAT16, but, FAT16 code might not be necessary, I took the following steps:
1. format the MMC with DOS command for FAT16 and 2048 bytes per cluster
(with MMC in USB reader as removable disk F:)
format F: /FS:FAT /A:2048 /V:MMC_32MB
if you got total a total space of 32,030,720 bytes and 15,640 clusters, then the starting address of your first file will be 0x00013a00
2. copy a dummy file of EXACTLY 1 MB into the MMC, say dummy_1.dat, 1048576 bytes = 2048 x 512 = 0x00100000, then, dummy_1.dat will start from 0x00013a00, and the next file will start from 0x00113a00
3. connect the MMC with you PIC, writing data from 0x00013a00 with the following initiate command, mmc_open_4_write(0x00, 0x01, 0x3a); keep writing upto 1 MB of data.
4. put the MMC back to USB reader, then you can get your data back by simply copy dummy_1.dat back.
That's all.
Best wishes
C-H Wu
Original Post ID: 11439 |
Richard Rolland Guest
Posted: Fri Mar 14, 2003 1:06 pm |
Hi, I am trying to do the same thing using a micro-controller to interface the CF card. I trying to find out the easiest way to create a file and append data to it. Did you have good success?
Original Post ID: 12676 |
vinash
help needed |
Posted: Thu Feb 09, 2006 3:01 am |
I am trying to interface a sd card to a micro-controller and implementing FAT16. If some has a code, I would be very grateful, if you could send it to me.My e-mail add is vinash123@hotmail.com.thank you. |
Posted: Thu Feb 09, 2006 8:09 am |
Use the search function of this forum before posting a question. You will get your answer much quicker and it saves us from reading the same questions over and over again. |
subodh Guest
Posted: Sun Feb 11, 2007 12:21 am |
John wrote: | Post your e-mail adress and I can mail you the complete files made by C-H Wu based on Tomi's code.
/John
Can you send me this code on subodh1978@yahoo.com
Subodh |
