Strings
rfjhh
Strings
PostPosted: Thu Mar 31, 2011 6:15 pm     Reply with quote
In PIC C, how can I use string type variables?
In c# I can define
string a;
a = "example";
PostPosted: Thu Mar 31, 2011 7:09 pm     Reply with quote
The short answer is, you have to declare an array to hold the string.
http://cplus.about.com/od/learningc/ss/strings.htm
bkamen
Re: Strings
PostPosted: Thu Mar 31, 2011 9:28 pm     Reply with quote
In c# I can define
string a;
a = "example";
I would also strongly recommend getting "The C Programming Language" by Kernighan & Ritchie
-Ben
eliasS
PostPosted: Thu May 05, 2011 11:35 am     Reply with quote
In the old C a string basically is an array of chars, if you want to declare a string variable you don't use string="dummy"; instead you use a char array and you can't initialize it like this char myString="dummy"; This will create an array of chars of 6 elements 'd' will be at this location myString[0] and 'y' in myString[5]
PostPosted: Thu May 05, 2011 2:55 pm     Reply with quote
99% right. The 'y' is at myString[4]. myString[5] contains the 'null terminator' '\0' character.
This is the only thing 'special' about strings. In C, a string is 'a null terminated array of characters. So a 5 character string, needs 6 characters of storage, the extra one for the terminator character.
Remember also, that since a 'string' is not a type in C, it has to be explicitly copied, either 'character by character', by looping through the array, or by using the string functions (which do this for you).
rfjhh
PostPosted: Thu May 05, 2011 7:12 pm     Reply with quote
I've got the answer... thank you
