rfjhh
| Strings |
Posted: Thu Mar 31, 2011 6:15 pm |
In PIC C, how can I use string type variables?
In c# I can define
string a;
a = "example";
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
| Re: Strings |
Posted: Thu Mar 31, 2011 9:28 pm |
| rfjhh wrote: | In PIC C, how can I use string type variables?
In c# I can define
string a;
a = "example";
I would also strongly recommend getting "The C Programming Language" by Kernighan & Ritchie
eliasS
Joined: 22 Jun 2010 Posts: 1 Location: Culiacan,Mexico
Posted: Thu May 05, 2011 11:35 am |
| In the old C a string basically is an array of chars, if you want to declare a string variable you don't use string="dummy"; instead you use a char array and you can't initialize it like this char myString="dummy"; This will create an array of chars of 6 elements 'd' will be at this location myString[0] and 'y' in myString[5] |
Posted: Thu May 05, 2011 2:55 pm |
99% right. The 'y' is at myString[4]. myString[5] contains the 'null terminator' '\0' character.
This is the only thing 'special' about strings. In C, a string is 'a null terminated array of characters. So a 5 character string, needs 6 characters of storage, the extra one for the terminator character.
Remember also, that since a 'string' is not a type in C, it has to be explicitly copied, either 'character by character', by looping through the array, or by using the string functions (which do this for you).
rfjhh
| Thanks |
Posted: Thu May 05, 2011 7:12 pm |
| I've got the answer... thank you |
