We are currently using the midrange micro PIC12F609. I used the PCWHD wizard to generate a small code that enabled the timer0 interrupt. But this does not seem to be working. Please could you help me out. The code is as below
setup_timer_0( RTCC_INTERNAL | RTCC_DIV_256 | RTCC_8_bit );
setup_comparator( NC_NC_NC_NC );// This device COMP currently not supported by the PICWizard
enable_interrupts( INT_TIMER0 );
enable_interrupts( GLOBAL );
