Interrupts on PIC12F609
shaunak_s
PostPosted: Fri Apr 29, 2011 5:44 am     Reply with quote
We are currently using the midrange micro PIC12F609. I used the PCWHD wizard to generate a small code that enabled the timer0 interrupt. But this does not seem to be working. Please could you help me out. The code is as below
#include <12F609.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES IOSC4                    //INTOSC speed 4 MHz
#use delay(int=4000000)
#byte STATUS    = 0x03
#bit REG_BANK   = 0x03.5
#byte OPTION_REG = 0x81
#define LED PIN_A1
#define DELAY 1000
#define MAX_SLEEP_CNT   1
int8 Sleep_Counter = 0;
#int_TIMER0
void  TIMER0_isr(void)
   Sleep_Counter = 1;
   int8 Toggle = 0;
   setup_timer_0( RTCC_INTERNAL | RTCC_DIV_256 | RTCC_8_bit );
   setup_comparator( NC_NC_NC_NC );// This device COMP currently not supported by the PICWizard
   enable_interrupts( INT_TIMER0 );
   enable_interrupts( GLOBAL );
    //Example blinking LED program
   while(true){
      if( Sleep_Counter ) {
         Sleep_Counter = 0;
         if( Toggle ) {
            Toggle = 0;
            output_low(LED);
            else {
               Toggle = 1;
                  output_high(LED);
PostPosted: Sun May 01, 2011 6:25 pm     Reply with quote
Try a more simple program, and use Pin A5 for the LED. See if it works.
Your LED circuit should look like this:
pin      330 ohms      LED
A5    ---/\/\/\/------->|----
                          -----  Ground
You can use a different resistor value if you don't have 330 ohms.
You could use 220 ohms or 470 ohms.
Here is the test program:
#include <12F609.h>
#fuses INTRC_IO,IOSC4,NOWDT,NOBROWNOUT
#define LED PIN_A5
#int_timer0
void  timer0_isr(void)
output_toggle(LED);  // Blink the LED
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_256);
If it doesn't work, post your compiler version.
