salgulsen
Having problems with PIC18F4620 I/Os |
Posted: Thu Mar 10, 2011 2:27 pm |
I'm trying this code to display a message.
I can use the same i/o's with 16F877a (the LCD shows the message) but can't use them with 18f4620 to drive a 4x20 lcd with flex lcd driver
I thought the ECCP pins or the Interrupt activated portb pins were the problem but it seems like they are not.
The code is :
Code: | #include <18f4620.h>
#Fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#device ADC=16
#use rs232(baud=19200, xmit=pin_C6, rcv=pin_C7, parity=N, stop=1)
#byte P1B = 0xFBD
#byte PORTD = 0xF83
#byte TRISD = 0xF95
#byte PORTB = 0xF81
#byte TRISB = 0xF93
#define cs PIN_C2
#define clk PIN_C3
#define sdo PIN_C5
#include <Flex_LCD420_2Proto.c>
#include <stdlib.h>
#include <math.h>
#include <Button.c>
void lcd_welcome()
lcd_gotoxy(1,1);
printf(lcd_putc," *****v0.7***** ");
Delay_ms(2000);
printf(lcd_putc,"\f");
port_b_pullups(TRUE);
setup_adc(ADC_CLOCK_DIV_64); //6.4 us de bir data oku =*250 = 1.6 ms
//setup_adc_ports(AN0_TO_AN1);
P1B = 0;
PORTD = 0;
PORTB = 0;
TRISD = 0;
TRISB = 0;
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_64);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_ccp1(CCP_OFF);
disable_interrupts(global);
lcd_init();
Store_Custom_Char();
lcd_welcome();
while (1){
lcd_welcome();
output_high(pin_A2);
output_low(pin_A2);
The LCD pins are :
// Flex_LCD420.c
// These pins are for my Microchip PicDem2-Plus board,
// which I used to test this driver.
// An external 20x4 LCD is connected to these pins.
// Change these pins to match your own board's connections.
#define LCD_DB4 PIN_D4
#define LCD_DB5 PIN_D5
#define LCD_DB6 PIN_D6
#define LCD_DB7 PIN_D7
#define LCD_RS PIN_B2
#define LCD_RW PIN_B4
#define LCD_E PIN_B5
Thanks for your help... |
Posted: Thu Mar 10, 2011 3:40 pm |
What is your CCS compiler version ? |
salgulsen
Posted: Thu Mar 10, 2011 5:02 pm |
my compiler version is 4.104 |
salgulsen
Posted: Fri Mar 11, 2011 2:39 pm |
I'm still out of clue what can cause the problem... ![Crying or Very sad](images/smiles/icon_cry.gif) |
Posted: Fri Mar 11, 2011 3:09 pm |
Delete 90% of your code and try a very simple test program:
#include <18F4620.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=4M)
#include <Flex_LCD420.c>
lcd_init();
lcd_putc("Hello World");
