Having problems with PIC18F4620 I/Os
salgulsen
PostPosted: Thu Mar 10, 2011 2:27 pm     Reply with quote
I'm trying this code to display a message.
I can use the same i/o's with 16F877a (the LCD shows the message) but can't use them with 18f4620 to drive a 4x20 lcd with flex lcd driver
I thought the ECCP pins or the Interrupt activated portb pins were the problem but it seems like they are not.
The code is :
#include <18f4620.h>
#Fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#device ADC=16
#use rs232(baud=19200, xmit=pin_C6, rcv=pin_C7, parity=N, stop=1)
#byte P1B = 0xFBD
#byte PORTD = 0xF83
#byte TRISD = 0xF95
#byte PORTB = 0xF81
#byte TRISB = 0xF93
#define cs PIN_C2
#define clk PIN_C3
#define sdo PIN_C5
#include <Flex_LCD420_2Proto.c>
#include <stdlib.h>
#include <math.h>
#include <Button.c>
void lcd_welcome()
   lcd_gotoxy(1,1);
   printf(lcd_putc,"   *****v0.7*****   ");
   Delay_ms(2000);
   printf(lcd_putc,"\f");
   port_b_pullups(TRUE);
   setup_adc(ADC_CLOCK_DIV_64); //6.4 us de bir data oku =*250 = 1.6 ms
   //setup_adc_ports(AN0_TO_AN1);
   P1B = 0;
   PORTD = 0;
   PORTB = 0;
   TRISD = 0;
   TRISB = 0;
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_64);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_ccp1(CCP_OFF);
   disable_interrupts(global);
   Store_Custom_Char();
   lcd_welcome();
   while (1){
      lcd_welcome();
      output_high(pin_A2);
      output_low(pin_A2);
The LCD pins are :
// Flex_LCD420.c
// These pins are for my Microchip PicDem2-Plus board,
// which I used to test this driver.
// An external 20x4 LCD is connected to these pins.
// Change these pins to match your own board's connections.
#define LCD_DB4   PIN_D4
#define LCD_DB5   PIN_D5
#define LCD_DB6   PIN_D6
#define LCD_DB7   PIN_D7
#define LCD_RS    PIN_B2
#define LCD_RW    PIN_B4
#define LCD_E     PIN_B5
Thanks for your help...
PostPosted: Thu Mar 10, 2011 3:40 pm     Reply with quote
What is your CCS compiler version ?
salgulsen
PostPosted: Thu Mar 10, 2011 5:02 pm     Reply with quote
my compiler version is 4.104
salgulsen
PostPosted: Fri Mar 11, 2011 2:39 pm     Reply with quote
I'm still out of clue what can cause the problem... Crying or Very sad
PostPosted: Fri Mar 11, 2011 3:09 pm     Reply with quote
Delete 90% of your code and try a very simple test program:
#include <18F4620.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=4M)
#include <Flex_LCD420.c>
lcd_putc("Hello World");
