18f4550 error with 4.119
hmmpic
PostPosted: Mon Feb 21, 2011 1:40 pm     Reply with quote
Hi
Something is wrong, maybe me. But my old working program wont compile after using 4.119.
The fuses INTRC_IO is changed to INTEC_IO why?
The complier wont let me select #use delay(clock=8M,int)
It complain there are no internal clock?
Try this?
#include "18f4550.h"
#FUSES INTEC_IO
void main(){
 While (1){;}
PostPosted: Mon Feb 21, 2011 3:30 pm     Reply with quote
Open up the header fuile and see what's inside for valid options....
Maybe the header info has changed or there's a 'bug'...
hmmpic
PostPosted: Mon Feb 21, 2011 3:49 pm     Reply with quote
The header file i changed from CCS?
But why does the #use delay(clock=8M,int) not working? The compiler reply me with no internal clk in this chip?
I think it's a bug.
Workaround:
void SetClk8M(){
 #byte OSCCON=0xfd3
 #asm
  MOVLW  0x70
  MOVWF  OSCCON
  MOVF   OSCCON,W
 #endasm
hmmpic
PostPosted: Tue Feb 22, 2011 9:37 am     Reply with quote
Maybe someone with 4.119 will make a 5 minutes test?
PostPosted: Tue Feb 22, 2011 2:43 pm     Reply with quote
Yes, I think it's a bug. Contact CCS tech support and ask them to fix
it in the next revision of the compiler.
