hmmpic
| 18f4550 error with 4.119 |
Posted: Mon Feb 21, 2011 1:40 pm |
Hi
Something is wrong, maybe me. But my old working program wont compile after using 4.119.
The fuses INTRC_IO is changed to INTEC_IO why?
The complier wont let me select #use delay(clock=8M,int)
It complain there are no internal clock?
Try this?
| Code: | #include "18f4550.h"
#FUSES INTEC_IO
void main(){
While (1){;}
Posted: Mon Feb 21, 2011 3:30 pm |
Open up the header fuile and see what's inside for valid options....
Maybe the header info has changed or there's a 'bug'... |
hmmpic
Posted: Mon Feb 21, 2011 3:49 pm |
The header file i changed from CCS?
But why does the #use delay(clock=8M,int) not working? The compiler reply me with no internal clk in this chip?
I think it's a bug.
Workaround:
| Code: | void SetClk8M(){
#byte OSCCON=0xfd3
#asm
MOVLW 0x70
MOVWF OSCCON
MOVF OSCCON,W
#endasm
hmmpic
Posted: Tue Feb 22, 2011 9:37 am |
| Maybe someone with 4.119 will make a 5 minutes test? |
Posted: Tue Feb 22, 2011 2:43 pm |
| Quote: | The complier wont let me select #use delay(clock=8M,int)
Yes, I think it's a bug. Contact CCS tech support and ask them to fix
it in the next revision of the compiler. |
