Dreyliciouss
Internal Error |
Posted: Mon Jan 17, 2011 1:44 am |
Hi everyone,
I have a problem when I try to compile any code with MPLAB and I have this error :
"Executing: "C:\Program Files (x86)\PICC\Ccsc.exe" "main.c" +FM +DF +LN +T -A +M +Z +Y=9 +EA
>>> Warning 203 "C:\Users\hureauau\Desktop\Logiciel\main.c" Line 69(1,1): Condition always TRUE
--- Info 300 "C:\Users\hureauau\Desktop\Logiciel\main.c" Line 72(1,2): More info: * Unable to write to main.PJT
*** Error 44 "C:\Users\hureauau\Desktop\Logiciel\main.c" Line 72(1,2): Internal Error - Contact CCS OUTPUT FILE P
1 Errors, 1 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Mon Jan 17 08:34:34 2011"
I tried to compile a simple code which is this one:
Code: | #include <18F452.h>
I have the same error.
Here is my code :
Code: | /**
* @file main.c
* Fichier principal de gestion de la ceinture de réveil
* @version 1.0
* @date 04/01/2011
* @author Audrey HUREAU
* Modifié le 14/01/2011
#include <12f683.h>
#include <stdlib.h>
#include <stdio.h>
#fuses INTRC_IO,NOBROWNOUT,NOMCLR,NOWDT,PROTECT,PUT,NOCPD,NOIESO,NOFCMEN,HS
#use delay(clock=8000000) //8MHz
/* Variables */
unsigned int arret=0;
float adc_value[6];
int i=0;
/* Fonction d'initialisation */
void init(void)
setup_oscillator(OSC_8MHZ); // select 8MHz internal clock
set_tris_a(0b00011011); // GP0,1,2 et 3 sont des entrées
setup_comparator(NC_NC);// On utilise pas de comparateur
setup_vref(FALSE);//On a pas besion de préciser la tension de ref utile au comparateur
setup_adc(ADC_CLOCK_INTERNAL);//Select ADC conversion clock
setup_adc_ports( AN3_ANALOG );//Seul GP4(AN3) est un port analogue
set_adc_channel(3);//sélection du channel AN3
delay_us(10);// Petit temps de délai après
output_low(PIN_A5);// Diode éteinte à la base
output_a(0b0000000);// 0 en sortie si pas d'arret respiratoire
/* Le module Detect() permet de scruter la sortie
de la jauge pendant un intervalle de temps */
void Detect(void)
//SLEEP();
do{
read_adc(ADC_START_ONLY);// Lecture de la valeur
adc_value[i] =read_adc(ADC_READ_ONLY);
if((adc_value[i]==adc_value[i-1]) && (adc_value[i]==adc_value[i-2]) && (adc_value[i]==adc_value[i-3])){
//on test si la valeur lue est égaleaux précédentes
arret=1;
//sinon on incrémente le i pour scruter plus lgt
i=i+1;
delay_ms(1000); /* On relève les valeurs toutes les secondes */
}while(arret==0); // On scrute tant qu'on a pas détecté d'arrêt
/* Fonction principale*/
init();
do{
Detect(); // appel à la fonction de détection pour commencer à scruter
setup_adc(ADC_OFF);
output_a(0b0000001); //Envoyer signal d'alarme à l'émetteur à la sortie du micro
output_high(PIN_A5); //Allumer la diode
}while(1);
Can anyone help me with the compiler? Do you think it can be a problem in my code?
Thank you. |
Mike Walne
Internal Error |
Posted: Mon Jan 17, 2011 4:51 pm |
Have you set the build options correctly?
I tried your simple "while (1) ;" code and got the Internal Error message and the others.
I then went into build options and set the MPASM option in place of the default CCS one.
Code then compiled without errors.
Mike |
Posted: Mon Jan 17, 2011 5:19 pm |
But what compiler version ? For you or him ? |
Posted: Mon Jan 17, 2011 9:37 pm |
Also what version of MPLAB !! v8.63 (latest) has an 'interesting' bug. |
