any successfully worked ADC example code?
dxdxdx
PostPosted: Tue Jan 11, 2011 7:18 am     Reply with quote
hello, till now I'm still fail to work on ADC... any one could kindly post up a successfully compiled and worked ADC code? just a simple one like on/off an LED will be enough... I'm just wanna refer how to write those code and modify it.. thanks alot
PostPosted: Tue Jan 11, 2011 8:49 am     Reply with quote
Just use the forum search. Literally hundreds of examples.
For instance:
http://www.ccsinfo.com/forum/viewtopic.php?t=44201&highlight=adc+example
http://www.ccsinfo.com/forum/viewtopic.php?t=44115&highlight=adc+example
PCM's test in the first, shows acquiring a number of readings, then displaying them. The original program in the second will work fine (depending on the noise sources present), while the damped version later, shows one way of dealing with this.
In the examples with the compiler. EX_ADMM.c
