hello, till now I'm still fail to work on ADC... any one could kindly post up a successfully compiled and worked ADC code? just a simple one like on/off an LED will be enough... I'm just wanna refer how to write those code and modify it.. thanks alot
Posted: Tue Jan 11, 2011 8:49 am
Just use the forum search. Literally hundreds of examples.
For instance:
PCM's test in the first, shows acquiring a number of readings, then displaying them. The original program in the second will work fine (depending on the noise sources present), while the damped version later, shows one way of dealing with this.
In the examples with the compiler. EX_ADMM.c
