Analysis of the ADC converter of the 18F458
Goto page Previous  1, 2
vever001
PostPosted: Tue Dec 14, 2010 4:38 pm     Reply with quote
Thanks a lot for your answers it really helps me Wink
So I suppose I shouldn't use the adc_done interruption since it isn't as precise/accurate as a simple delay.
I have one more question:
Do I need to do something except changing the instruction #device adc=10 to #device adc=8 if I want to use the A/D module as a 8 bit converter ?
Thanks for your help
vever001
PostPosted: Tue Dec 14, 2010 7:54 pm     Reply with quote
Are you sure it needs 30 + instructions to quit the instruction handler ?
Because I see the retfie instruction who seems to quit the instruction (handler ?).
Ttelmah wrote:
Tacq, _can_ be programmed into the chips on the latter PICs.
What do you mean by programming the Tacq ?
It is just a delay...I don't really understand and what's the advantage...
PostPosted: Tue Dec 14, 2010 8:11 pm     Reply with quote
See this thread which explains the CCS interrupt handler code:
http://www.ccsinfo.com/forum/viewtopic.php?t=29173
You can see the code for yourself by looking at the the .LST file.
Look at address 0004 for 16F PICs, or at address 0008 for 18F PICs.
Page 2 of 2
