So I suppose I shouldn't use the adc_done interruption since it isn't as precise/accurate as a simple delay.
I have one more question:
Do I need to do something except changing the instruction #device adc=10 to #device adc=8 if I want to use the A/D module as a 8 bit converter ?
Thanks for your help
vever001
Posted: Tue Dec 14, 2010 7:54 pm
Are you sure it needs 30 + instructions to quit the instruction handler ?
Because I see the retfie instruction who seems to quit the instruction (handler ?).
Ttelmah wrote:
Tacq, _can_ be programmed into the chips on the latter PICs.
What do you mean by programming the Tacq ?
It is just a delay...I don't really understand and what's the advantage...
Posted: Tue Dec 14, 2010 8:11 pm
Page 2 of 2
