zephyr2009
PLEASE HELP: Water Level Program |
Posted: Fri Sep 03, 2010 6:01 am |
Quote: | ////////////////////////////SENSOR FUNCTION////////////////////////////////////
void check_sensor()
if (!(input(SENSOR_LEVEL_4))&& (!input(SENSOR_LEVEL_3))&& (!input(SENSOR_LEVEL_2))&& (!input(SENSOR_LEVEL_1))){
water_level = 4;
else if ((input(SENSOR_LEVEL_4))&& (!input(SENSOR_LEVEL_3))&& (!input(SENSOR_LEVEL_2))&& (!input(SENSOR_LEVEL_1))){
water_level = 3;
else if((input(SENSOR_LEVEL_4))&& (input(SENSOR_LEVEL_3))&& (!input(SENSOR_LEVEL_2))&& (!input(SENSOR_LEVEL_1))){
water_level = 2;
else if((input(SENSOR_LEVEL_4))&& (input(SENSOR_LEVEL_3))&& (input(SENSOR_LEVEL_2))&& (!input(SENSOR_LEVEL_1))){
water_level = 1;
else{
water_level = 0;
is my program correct?
all levels are active high
and all levels have pull down resistor to ground
LEVEL 1 = PORTA1
LEVEL 2 = PORTA2
LEVEL 3 = PORTA3
LEVEL 4 = PORTA4
when there are no switches that are "shorted", it means the desired output is level 0
when level 1 float switch is shorted = level 1
when level 1 and 2 are shorted = level 2
level 1,2, and 3 are shorted = level 3
when level 1,2,3, and 4 are shorted = level 4
are the codes above correct? because my problem is when all switches are "open" the output is LEVEL 4 which is supposedly to output LEVEL 0...
PLEASE HELP ME!! Thanks in advance |
dyeatman
Posted: Fri Sep 03, 2010 6:30 am |
What processor?
Check the data sheet. I think you will find pin A4 is special....open collector. _________________ Google and Forum Search are some of your best tools!!!! |
Wayne_
Re: PLEASE HELP: Water Level Program |
Posted: Fri Sep 03, 2010 7:06 am |
zephyr2009 wrote: |
I think your logic is worng n your code. You have pull downs on the pins so the other side of the switch must be VDD.
So your truth table is:-
water L1 L2 L3 L4
0 0 0 0 0
1 1 0 0 0
2 1 1 0 0
3 1 1 1 0
4 1 1 1 1
Your code is opposite to this:-
void check_sensor()
water_level = 4;
water_level = 3;
water_level = 2;
water_level = 1;
else{
water_level = 0;
The ! means not or false so if L4 and L3 and L2 and L1 are all false (0) then you set water_level = 4.
This does not match your description.
Change code to
void check_sensor()
if (input(SENSOR_LEVEL_4)&& input(SENSOR_LEVEL_3) && input(SENSOR_LEVEL_2) && input(SENSOR_LEVEL_1)) {
water_level = 4;
else if (input(SENSOR_LEVEL_3) && !input(SENSOR_LEVEL_2) && input(SENSOR_LEVEL_1)) {
water_level = 3;
else if (input(SENSOR_LEVEL_2) && input(SENSOR_LEVEL_1)) {
water_level = 2;
else if (input(SENSOR_LEVEL_1)) {
water_level = 1;
else {
water_level = 0;
You may notice you don't have to check each one as the previous condition rules out the logic. Unless there is the possibility of incorrect readings. |
Wayne_
Posted: Fri Sep 03, 2010 7:14 am |
you can simplify this because you are using pins A1, A2, A3 and A4
int8 val;
val = (input_a() >> 1) & 0x0F; // Get the input and adjust for A1 to A4
if (val & 0x0f) // L4 = 1, L3 = 1, L2 = 1, L1 = 1
water_level = 4;
else if (val & 0x07) // L3 = 1, L2 = 1, L1 = 1
water_level = 3;
else if (val & 0x03) // L2 = 1, L1 = 1
water_level = 2;
else if (val & 0x01) // L1 = 1
water_level = 1;
water_level = 0;
I think. |
zephyr2009
Posted: Fri Sep 03, 2010 9:14 am |
Code: | water L1 L2 L3 L4
0 0 0 0 0
1 1 0 0 0
2 1 1 0 0
3 1 1 1 0
4 1 1 1 1 |
Thank you sir wayne for replying...
Your right sir
my truth table is just like that...
I will try your codes with respect to my codes
I hope that it would work.. |
zephyr2009
Posted: Fri Sep 03, 2010 11:08 am |
Code: | else if (input(SENSOR_LEVEL_3) && !input(SENSOR_LEVEL_2) && input(SENSOR_LEVEL_1)) {
water_level = 3;
Good day sir..
It is a great code..
My water level works fine!
I noticed that your code && !input(SENSOR_LEVEL_3) has a ! (not) and i deleted it to make my level 3 = 1 1 1 0 as the truth table
Code: | else if (input(SENSOR_LEVEL_3) && input(SENSOR_LEVEL_2) && input(SENSOR_LEVEL_1)) {
water_level = 3;
Thank you very much sir wayne..
Hope that you could still help me if i found another problem |
Wayne_
Posted: Mon Sep 06, 2010 1:52 am |
Glad to help, that ! must have been a typo |
