PLEASE HELP: Water Level Program
zephyr2009
PostPosted: Fri Sep 03, 2010 6:01 am     Reply with quote
////////////////////////////SENSOR FUNCTION////////////////////////////////////
void check_sensor()
if (!(input(SENSOR_LEVEL_4))&& (!input(SENSOR_LEVEL_3))&& (!input(SENSOR_LEVEL_2))&& (!input(SENSOR_LEVEL_1))){
water_level = 4;
else if ((input(SENSOR_LEVEL_4))&& (!input(SENSOR_LEVEL_3))&& (!input(SENSOR_LEVEL_2))&& (!input(SENSOR_LEVEL_1))){
water_level = 3;
else if((input(SENSOR_LEVEL_4))&& (input(SENSOR_LEVEL_3))&& (!input(SENSOR_LEVEL_2))&& (!input(SENSOR_LEVEL_1))){
water_level = 2;
else if((input(SENSOR_LEVEL_4))&& (input(SENSOR_LEVEL_3))&& (input(SENSOR_LEVEL_2))&& (!input(SENSOR_LEVEL_1))){
water_level = 1;
else{
water_level = 0;
is my program correct?
all levels are active high
and all levels have pull down resistor to ground
LEVEL 1 = PORTA1
LEVEL 2 = PORTA2
LEVEL 3 = PORTA3
LEVEL 4 = PORTA4
when there are no switches that are "shorted", it means the desired output is level 0
when level 1 float switch is shorted = level 1
when level 1 and 2 are shorted = level 2
level 1,2, and 3 are shorted = level 3
when level 1,2,3, and 4 are shorted = level 4
are the codes above correct? because my problem is when all switches are "open" the output is LEVEL 4 which is supposedly to output LEVEL 0...
PLEASE HELP ME!! Thanks in advance
PostPosted: Fri Sep 03, 2010 6:30 am     Reply with quote
What processor?
Check the data sheet. I think you will find pin A4 is special....open collector.
Wayne_
Re: PLEASE HELP: Water Level Program
PostPosted: Fri Sep 03, 2010 7:06 am     Reply with quote
I think your logic is worng n your code. You have pull downs on the pins so the other side of the switch must be VDD.
So your truth table is:-
water L1 L2 L3 L4
0      0   0   0  0
1      1   0   0  0
2      1   1   0  0
3      1   1   1  0
4      1   1   1  1
Your code is opposite to this:-
void check_sensor()
water_level = 4;
water_level = 3;
water_level = 2;
water_level = 1;
else{
water_level = 0;
The ! means not or false so if L4 and L3 and L2 and L1 are all false (0) then you set water_level = 4.
This does not match your description.
Change code to
void check_sensor()
if (input(SENSOR_LEVEL_4)&& input(SENSOR_LEVEL_3) && input(SENSOR_LEVEL_2) && input(SENSOR_LEVEL_1)) {
water_level = 4;
else if (input(SENSOR_LEVEL_3) && !input(SENSOR_LEVEL_2) && input(SENSOR_LEVEL_1)) {
water_level = 3;
else if (input(SENSOR_LEVEL_2) && input(SENSOR_LEVEL_1)) {
water_level = 2;
else if (input(SENSOR_LEVEL_1)) {
water_level = 1;
else {
water_level = 0;
You may notice you don't have to check each one as the previous condition rules out the logic. Unless there is the possibility of incorrect readings.
Wayne_
PostPosted: Fri Sep 03, 2010 7:14 am     Reply with quote
you can simplify this because you are using pins A1, A2, A3 and A4
int8 val;
val = (input_a() >> 1) & 0x0F; // Get the input and adjust for A1 to A4
if (val & 0x0f)  // L4 = 1, L3 = 1, L2 = 1, L1 = 1
  water_level = 4;
else if (val & 0x07) // L3 = 1, L2 = 1, L1 = 1
  water_level = 3;
else if (val & 0x03) // L2 = 1, L1 = 1
  water_level = 2;
else if (val & 0x01) // L1 = 1
  water_level = 1;
  water_level = 0;
I think.
zephyr2009
PostPosted: Fri Sep 03, 2010 9:14 am     Reply with quote
water L1 L2 L3 L4
0      0   0   0  0
1      1   0   0  0
2      1   1   0  0
3      1   1   1  0
4      1   1   1  1
Thank you sir wayne for replying...
Your right sir
my truth table is just like that...
I will try your codes with respect to my codes Smile
I hope that it would work.. Smile
zephyr2009
PostPosted: Fri Sep 03, 2010 11:08 am     Reply with quote
water_level = 3;
Good day sir..
It is a great code.. Smile
My water level works fine! Smile
I noticed that your code && !input(SENSOR_LEVEL_3) has a ! (not) and i deleted it to make my level 3 = 1 1 1 0 as the truth table
else if (input(SENSOR_LEVEL_3) && input(SENSOR_LEVEL_2) && input(SENSOR_LEVEL_1)) {
water_level = 3;
Thank you very much sir wayne..
Hope that you could still help me if i found another problem Smile
Wayne_
PostPosted: Mon Sep 06, 2010 1:52 am     Reply with quote
Glad to help, that ! must have been a typo Embarassed
