How to use 8 Mhz clock to generate slow PWM Frequencies
Posted: Mon Aug 30, 2010 1:30 pm
I am using the PIC18F2480 and one of the goals of my project is to output PWM signals with slow frequencies (between 10 - 100 Hz). I know how to accomplish this through setting the internal oscillator frequency much lower (125Khz or 250Khz); however, I would like to be able to use the normal 8 Mhz clock frequency or somewhere in the Mhz range.
Would it be possible to hook up a slow external crystal or oscillator for the timer to use to generate the PWM signals, but to run the main program from the internal 8 Mhz clock? Or are there any other ways to accomplish this?
Thanks.
Here's some sample code I'm using to generate, if it helps:
