How to use 8 Mhz clock to generate slow PWM Frequencies
Brian
PostPosted: Mon Aug 30, 2010 1:30 pm     Reply with quote
I am using the PIC18F2480 and one of the goals of my project is to output PWM signals with slow frequencies (between 10 - 100 Hz). I know how to accomplish this through setting the internal oscillator frequency much lower (125Khz or 250Khz); however, I would like to be able to use the normal 8 Mhz clock frequency or somewhere in the Mhz range.
Would it be possible to hook up a slow external crystal or oscillator for the timer to use to generate the PWM signals, but to run the main program from the internal 8 Mhz clock? Or are there any other ways to accomplish this?
Thanks.
Here's some sample code I'm using to generate, if it helps:
    setup_oscillator(OSC_125KHZ);
   setup_timer_2(T2_DIV_BY_16, 255, 1);
   setup_ccp1(CCP_PWM);
        set_pwm1_duty(395L);
PostPosted: Mon Aug 30, 2010 1:36 pm     Reply with quote
Look at the software PWM routines in this thread, using #int_rtcc (Timer0):
http://www.ccsinfo.com/forum/viewtopic.php?t=37807
Brian
PostPosted: Tue Aug 31, 2010 1:28 pm     Reply with quote
Thanks very much. I posted an additional question on one of the threads already created here:
http://www.ccsinfo.com/forum/viewtopic.php?p=137266#137266
Thanks.
