Float to byte conversion
tahiticecil
PostPosted: Mon Aug 30, 2010 5:36 am     Reply with quote
Hello everyone !
I would like to know how to convert a float number (value is always between 0 and 255) to a byte like this :
Float value 5,023 should be converted to 5 in my byte, 127.845 => 127 etc.
Any ideas ?
Best Regards,
Clément.
mkuang
PostPosted: Mon Aug 30, 2010 7:23 am     Reply with quote
You mean just keep the integer part of it?
You can do:
unsigned char my_integer;
float my_float;
my_integer = (unsigned char) my_float;
SherpaDoug
PostPosted: Mon Aug 30, 2010 3:54 pm     Reply with quote
In the general C language lingo you want to "cast" the float to an 8 bit int. The compiler should do this automatically, but to be really sure you can do what mkuang shows.
This
is an explicit cast, whereas simply
my_integer = my_float;
should do an automatic cast.
tahiticecil
PostPosted: Tue Aug 31, 2010 5:23 am     Reply with quote
Hi !
I hadn't thought that a simple cast could work. I tried to work directly on each bytes of a float var to get the integer part.
Thank you for your help.
Clément
