I would like to know how to convert a float number (value is always between 0 and 255) to a byte like this :
Float value 5,023 should be converted to 5 in my byte, 127.845 => 127 etc.
Posted: Mon Aug 30, 2010 3:54 pm
In the general C language lingo you want to "cast" the float to an 8 bit int. The compiler should do this automatically, but to be really sure you can do what mkuang shows.
This
my_integer = (unsigned char) my_float;
is an explicit cast, whereas simply
my_integer = my_float;
should do an automatic cast. _________________ The search for better is endless. Instead simply find very good and get the job done.
tahiticecil
Posted: Tue Aug 31, 2010 5:23 am
Hi !
I hadn't thought that a simple cast could work. I tried to work directly on each bytes of a float var to get the integer part.
