Keypad design and the behavior of output_float()
kd5uzz
PostPosted: Sun Aug 08, 2010 4:54 pm     Reply with quote
Hello everyone.
I'm designing a PCB that will incorporate a 4x4 keypad. I would like to be able to detect and decode multiple key-presses.
In an effort to save space on the board I would like to use the minimum number of components. Each input will need a pull-up or pull-down resistor (depends on the rest of the keypad design).
I see some designs that use resistors on the ROW lines to limit the current sourced by the PIC on those lines. I also see some designs that use diodes, the stated reason is to allow the decoding of multiple key-presses.
The code below uses output_high and output_low. My question is:
Can I instead use output_float on the ROWs I'm not checking, and use output_low on the 'active' row, allowing the pull-ups to pull the 'FLOAT' pins high? Why wouldn't this detect (and decode) multiple key presses (without the use of diodes)?
I feel like I'm missing something.
For the record I intend on using the RTOS to run a task similar to the code below every 100ms or so - any thoughts as to if that is too often/not often enough?
Example:
Assume a 4x4 keypad, user is holding (A,1), (B,1) and (B,2).
  output_high(ROW_A);
  output_low(ROW_B);
  output_low(ROW_C);
  output_low(ROW_D);
  if (input(COL_1))
      //key A,1
  if (input(COL_2))
      //key A,2
  if (input(COL_3))
      //key A,3
  if (input(COL_4))
      //key A,4
  output_low(ROW_A);
  output_high(ROW_B);
  output_low(ROW_C);
  output_low(ROW_D);
  if (input(COL_1))
      //key B,1
  if (input(COL_2))
      //key B,2
  if (input(COL_3))
      //key B,3
  if (input(COL_4))
      //key B,4
  output_low(ROW_A);
  output_low(ROW_B);
  output_high(ROW_C);
  output_low(ROW_D);
  if (input(COL_1))
      //key C,1
  if (input(COL_2))
      //key C,2
  if (input(COL_3))
      //key C,3
  if (input(COL_4))
      //key C,4
  output_low(ROW_A);
  output_low(ROW_B);
  output_low(ROW_C);
  output_high(ROW_D);
  if (input(COL_1))
      //key D,1
  if (input(COL_2))
      //key D,2
  if (input(COL_3))
      //key D,3
  if (input(COL_4))
      //key D,4
PostPosted: Sun Aug 08, 2010 8:30 pm     Reply with quote
The CCS kbd.c keypad driver floats the row pins, with a pull-up on each
pin. It then sets each column pin low, one at a time, and reads the row
pins to detect a keypress. That's similar to what you want to do, in
terms of scanning the keypad.
kd5uzz
PostPosted: Mon Aug 09, 2010 5:51 pm     Reply with quote
PCM,
Ah, exactly what I was thinking except swap ROWs for COLs, thank you.
Can someone explain what would happen if, using a basic matrix keypad with this code, would happen during multiple key presses? I don't see why I wouldn't be able to detect and decode multiple key presses.
PostPosted: Mon Aug 09, 2010 11:41 pm     Reply with quote
Here are some articles on keypad rollover issues:
http://www.lintech.org/comp-per/04KB.pdf
http://www.national.com/an/AN/AN-734.pdf
http://www.dribin.org/dave/keyboard/one_html
FvM
PostPosted: Mon Aug 09, 2010 11:56 pm     Reply with quote
In a short: Two-key-presses can be decoded without diodes, more than two possibly not.
kd5uzz
PostPosted: Wed Aug 11, 2010 11:32 am     Reply with quote
Thanks everyone. The links were very useful.
