kd5uzz
Keypad design and the behavior of output_float() |
Posted: Sun Aug 08, 2010 4:54 pm |
Hello everyone.
I'm designing a PCB that will incorporate a 4x4 keypad. I would like to be able to detect and decode multiple key-presses.
In an effort to save space on the board I would like to use the minimum number of components. Each input will need a pull-up or pull-down resistor (depends on the rest of the keypad design).
I see some designs that use resistors on the ROW lines to limit the current sourced by the PIC on those lines. I also see some designs that use diodes, the stated reason is to allow the decoding of multiple key-presses.
The code below uses output_high and output_low. My question is:
Can I instead use output_float on the ROWs I'm not checking, and use output_low on the 'active' row, allowing the pull-ups to pull the 'FLOAT' pins high? Why wouldn't this detect (and decode) multiple key presses (without the use of diodes)?
I feel like I'm missing something.
For the record I intend on using the RTOS to run a task similar to the code below every 100ms or so - any thoughts as to if that is too often/not often enough?
Example:
Assume a 4x4 keypad, user is holding (A,1), (B,1) and (B,2).
Code: | {
output_high(ROW_A);
output_low(ROW_B);
output_low(ROW_C);
output_low(ROW_D);
if (input(COL_1))
//key A,1
if (input(COL_2))
//key A,2
if (input(COL_3))
//key A,3
if (input(COL_4))
//key A,4
output_low(ROW_A);
output_high(ROW_B);
output_low(ROW_C);
output_low(ROW_D);
if (input(COL_1))
//key B,1
if (input(COL_2))
//key B,2
if (input(COL_3))
//key B,3
if (input(COL_4))
//key B,4
output_low(ROW_A);
output_low(ROW_B);
output_high(ROW_C);
output_low(ROW_D);
if (input(COL_1))
//key C,1
if (input(COL_2))
//key C,2
if (input(COL_3))
//key C,3
if (input(COL_4))
//key C,4
output_low(ROW_A);
output_low(ROW_B);
output_low(ROW_C);
output_high(ROW_D);
if (input(COL_1))
//key D,1
if (input(COL_2))
//key D,2
if (input(COL_3))
//key D,3
if (input(COL_4))
//key D,4
Posted: Sun Aug 08, 2010 8:30 pm |
The CCS kbd.c keypad driver floats the row pins, with a pull-up on each
pin. It then sets each column pin low, one at a time, and reads the row
pins to detect a keypress. That's similar to what you want to do, in
terms of scanning the keypad. |
kd5uzz
Posted: Mon Aug 09, 2010 5:51 pm |
PCM,
Ah, exactly what I was thinking except swap ROWs for COLs, thank you.
Can someone explain what would happen if, using a basic matrix keypad with this code, would happen during multiple key presses? I don't see why I wouldn't be able to detect and decode multiple key presses. |
FvM
Posted: Mon Aug 09, 2010 11:56 pm |
Quote: | I don't see why I wouldn't be able to detect and decode multiple key presses. |
In a short: Two-key-presses can be decoded without diodes, more than two possibly not. |
kd5uzz
Posted: Wed Aug 11, 2010 11:32 am |
Thanks everyone. The links were very useful. |
