Design( prototype - proteus ISIS) is already working fine with external component DS1307. I like to add another external component for UART to USB conversion CDC function (MCP2200). I would like to use less external components.
Both tease functions could be found in different PIC, but my limit is deadline to present a OK working prototype.
-------- DS1307 vs RTCC ------
- If The power goes off DS1307 keeps ticking, how i can solve this problem with PIC? Low voltage detection and quick work flow product loss elimination? + how to keep PIC RTCC ticking during external power source failure?
--------MCP2200 --------
So far as i understand there will be no need for complicated configuration code for simple functions as one way communication. My target is only sending data for information purpose to final user laptop PC without additional software. Can i get what i want by connection PIC UART Rx Tx pins + some more external components to MCP2200.
Thank you in advance !
Posted: Tue Jul 06, 2010 1:18 pm
Google is the best place to search for an answer. Use this search string:
