shhn
16F876 random number |
Posted: Mon Jun 14, 2010 8:38 am |
i want to generate random number from 16f876 every 1 seconds and i want to read rs232 this numbers. how can i write this code? please help |
mkuang
Posted: Mon Jun 14, 2010 8:41 am |
When is your homework assignment due? |
shhn
Posted: Mon Jun 14, 2010 8:48 am |
no i m not student, only I m interested pic and I want to develop some projects with pic
also i now c and cpp but in this issue i have is missing |
mkuang
Posted: Mon Jun 14, 2010 9:10 am |
You can try this:
#include <16F876.h>
#include <math.h>
#use delay(clock=8000000)
#fuses INTRC,NOWDT,PUT,NOBROWNOUT,NOLVP
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,ERRORS)
int8 random_number;
while{1}
random_number = (int8)(10*randn()); //generate a random number between zero and 10
printf("\n\rThis is a random nymber: %u", random_number);
delayh_ms(1000); //prints every 10 seconds
| THis uses the internal oscillator at 8Mhz. Make sure you have a MAX232 or equivalent RS232 chip connected via hardware UART pins of the PIC (C6 and C7).
Look at this thread to see how to hook up the hardware.
http://www.ccsinfo.com/forum/viewtopic.php?t=42784 |
shhn
Posted: Mon Jun 14, 2010 11:45 am |
Thanks for your reply.
I compiled your code and put in pic, now, I want to test pic. How to generate random number? How can I do this? |
mkuang
Posted: Mon Jun 14, 2010 11:48 am |
What kind of hardware do you have? IF you want to display something on a PC (like on hyperterminal) you need to make a serial cable. You will need something similar to the schematic I linked to in my previous post. |
Humberto
Posted: Mon Jun 14, 2010 11:55 am |
There is a built in function that can generate random numbers, it use stdlib.h where you can define
the maximum number (RAND_MAX) to generate.
Humberto |
shhn
Posted: Mon Jun 14, 2010 12:03 pm |
mkuang wrote: | What kind of hardware do you have? IF you want to display something on a PC (like on hyperterminal) you need to make a serial cable. You will need something similar to the schematic I linked to in my previous post. |
i have this USB PIC Programmer (D149BC). i connect it with usb cable.
![](http://www.denizelektronik.com/d149_bc_rev1byk.jpg) |
mkuang
Posted: Mon Jun 14, 2010 12:41 pm |
The silver connector on the lower left corner is an ethernet connector right? And you connect that to the programmer?
What programmer do you have? |
SherpaDoug
Posted: Mon Jun 14, 2010 1:43 pm |
mkuang wrote: | The silver connector on the lower left corner is an ethernet connector right? And you connect that to the programmer?
It looks like USB to me. I think this IS his programmer. What I would want is a schematic of the PIC target, the board that the PIC runs on. _________________ The search for better is endless. Instead simply find very good and get the job done. |
